Alexjcr
I’ve recently bought a MK6 JSW and while it’s in great mechanical condition, I’ve noticed in the past few days that the temperature knob is a little finicky. I’m sure the problem isn’t the knob but the temperature that I select doesn’t seem to match with the air temperature coming out of the vents. At least it does blow cold air, almost too much. About 3/4 of the range of the knob’s movement makes it blow cold air. I am in Florida, so outside cold weather isn’t a factor here. This is regardless of whether the air recirculation is on or off. I’m sure a sensor is bad somewhere in the AC system. I don’t know much about AC. Any of the AC gurus might suggest where to look for problems. Thank you all!
