Old February 8th, 2019, 15:26   #1
jmodge
Default Toyota crank
Can someone provide me with the dimension from the face of the flywheel mounting surface on the crank to the bell housing mounting surface on the block of a Toyota engine? I want to compare it to the ALH dimension, which I have, to design my flywheel adapter
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old February 9th, 2019, 10:40   #2
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
3/8" 9.5mm
1.9ZOOK is offline   Reply With Quote
Old February 9th, 2019, 13:58   #3
jmodge
thanks zook
Old February 9th, 2019, 14:33   #4
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
No prob......
Free crank pulley holder tool for torquing crank bolt Shawn MacAnanny VW MKIII-A3/B4 TDIs 2 June 15th, 2017 19:09
Want to RENT crank lock and crank seal install tools sangretdi Private TDI Items for Sale/Wanted 3 October 10th, 2013 11:17
bent lower crank pulley? crank snout problems?? 1997 ahu samuraitd TDI 101 13 March 31st, 2013 17:30
How do I hold crank to torque the crank timing belt sprocket? dslemaire VW MKIV-A4 TDIs (VE and PD) 1 July 17th, 2009 11:24
Crank Pulley Holding Fixture to Tighten Crank Bolt ninedee_golf_tdi TDI 101 2 March 6th, 2008 07:11
Page generated in 0.11354 seconds with 11 queries
[Output: 62.57 Kb. compressed to 55.95 Kb. by saving 6.62 Kb. (10.59%)]
