Old December 31st, 2018, 09:02   #16
eddieleephd
Fuel Economy: 38mix / 47@70-75
Ah, okay, makes sense. Definitely wait then, and as said by vwztips you'll likely need to clear the loader and start over with it. You should be able to pull the files and reload it with Matt's help.
Sent from my Armor_2 using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old December 31st, 2018, 09:03   #17
superhl
Originally Posted by vwztips View Post
Do you have the software to download the EEN file to your PC? You will need this to download both files. Then clear the loader. You will then have to pick the ECU you are workubg with and load that program. Next read the ECU. Then load EEN program via PC, then load to ECU.
I don't have the software to download the EEN file. Maybe that is what I am missing. Matt is probably on vacation. He just told me to wait until the loader arrives but no instructions came with it so I am completely lost.
superhl is offline   Reply With Quote
Old December 31st, 2018, 09:05   #18
eddieleephd
The software is downloadable, the VIN being locked and not the same is the issue. Programming is on the loader already, he'll got you set-up when he gets back.
Old January 15th, 2019, 19:54   #19
superhl
I received the download from Matt. Erased the loader and installed new software. Capture the config file and sent to Matt. Mean while, I am driving home and noticed the IP not as noisy as previously. Engine was running perfect. Late that evening, I made some changes to wiring on my heater and the next morning, truck was hard starting. Once started, lots of white smoke with a heavy smell of diesel. I check the timing and it appears graph off the wall. I set the timing again and moved counter clockwise gave it pretty good bump. Still off the chart. Could the belt jumped a tooth.
Old January 16th, 2019, 05:02   #20
eddieleephd
Absolutely. Have to check that manually, otherwise it's just speculation.
Old February 4th, 2019, 10:49   #21
superhl
I received the tuner program a couple of weeks ago, it resolved the starting issues. However, while driving and testing just as I was arriving home, it overheated. It was pushing water out of the radiator. I removed the bottom radiator that connects to the Thermostat, no water was circulating. After researching, I thought it must be the thermostat or water pump. I replaced them and replaced timing belt. Put it back together, but have not driven yet. I noticed when I fill the expansion tanks(fish bowl) to level, my radiator over flows. The bottom outlet on the fish bowl, is connected to the outlet next to the thermostat? I put a level on the fish bowl and radiator thinking I may have it too high but not sure how much lower it should be than the top radiator outlet. The temp was averaging around 140 before overheating.
1. Could it be my head gasket
2. It there a better way to gauge the temperature? Currently have sensor installed between hose that connects to top radiator. Should i purchase a Scangauge?
3. How is the best way to test for head gasket blown.
Parts for Sale/Trade from Those Completing Buybacks? blaupunked Dieselgate - VW Group Emission Scandal 2 December 2nd, 2016 16:50
To Tune or not TO Tune (my ECU without a DSG tune) TL A3 Audi A3 8 August 18th, 2012 16:45
To Tune or not TO Tune (my ECU without a DSG tune) TL A3 TDI Power Enhancements 0 August 14th, 2012 10:30
Need help completing Timing Belt Change! max3fan TDI 101 1 January 12th, 2006 22:45
Page generated in 0.13376 seconds with 11 queries
[Output: 76.95 Kb. compressed to 67.50 Kb. by saving 9.45 Kb. (12.28%)]
