Old May 9th, 2010, 10:09   #1
JoaoT4
JoaoT4's Avatar
Default VW T4 Westfalia Engine Conversion
I finished the engine mount on the conversion I'm doing. I'm installing a 1.9 TDI AGR engine on my VW T4 California.
A picture of the mount finished and painted
Joćo
JoaoT4 is offline   Reply With Quote
Old May 9th, 2010, 14:33   #2
TurbinePower
TDI(s): None
How about some pictures of the car that it's going into?
Originally Posted by FL2AK-tdi
I just wish that it would stop breaking. If I could go one OCI without something breaking, I would be a huge VW fan lol.
Small stable of VWs (projects)...
'80 Dasher Diesel, full restoration in the slow burner works
'82 Quantum "Coupe" 1.6 CIS gas power, daily driver
'89 Fox wagon (Korva!), the new back porch project. Suspension and interior work in progress!
TurbinePower is offline   Reply With Quote
Old May 9th, 2010, 16:07   #3
JoaoT4
JoaoT4's Avatar
Ok. Here they are. I hope you like it
Joćo
Without engine
New Engine
Gearbox clean and ready to go
Old May 9th, 2010, 17:46   #4
mogly
Nice project. I'm not familiar with the AGR, how many hp? VNT? What did you use for a trans? Did you use a FMIC?
mogly is offline   Reply With Quote
Old May 9th, 2010, 18:07   #5
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
how about some pics of the Beetle in the background, what year? '72
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old May 10th, 2010, 14:02   #6
JoaoT4
JoaoT4's Avatar
The AGR has 90HP but the case is the same of the 110HP. Only the injectors and the turbo are different. The AGR turbo is not the VNT. I can get a VNT for free but need to be repaired. I would also need to change the N75. The gearbox is the original that came with the van. I only change the 5th ratio gear. The gearbox isn’t very strong so I can’t put a lot of HP on it.
Old May 10th, 2010, 14:34   #7
JoaoT4
JoaoT4's Avatar
off-topic
Yep it's a 72 super beetle 1302 in Europe. I upgrade the engine to a 1600DP since the original engine was a AB 1300DB. It's a jubilee. My father bought it new in June of 1972 and is on the family since then. Great car never broke
Joćo
Old May 10th, 2010, 18:09   #8
CFM
Fuel Economy: All-time best of 73.2 mpg so far...
Neat! I have a 1960 Bug with a Berg-5 and Berg 1776...haven't driven it in a few years (too many other things going on right now), but it's a blast to drive! I've also had the privilege of driving some early VWs...a '49 Hebmuller, a '50 Standard, a '53 convertible, and a Judson-powered '53 split. All were fun and drove very nice, even with the crashbox transaxles they came with back then...
CFM is offline   Reply With Quote
Old May 10th, 2010, 19:18   #9
ninedee_golf_tdi
Sounds like a neat project, you need to turn the heat up on the welder to get deeper penetration then what you show in that picture.
ninedee_golf_tdi is offline   Reply With Quote
Old May 11th, 2010, 00:49   #10
JoaoT4
JoaoT4's Avatar
Thanks for the reply put the welder was on its maximum power. It has two layers of welding. I hope it can handle the engine without broke.
Joćo
Old May 16th, 2010, 09:56   #11
JoaoT4
JoaoT4's Avatar
Default VW T4 1.9 TDI Conversion
The dimensions of the engine mount were correct and the engine entered with no problems.
The vacuum line to the brakes and the fuel lines are connected. The tubes that go from the filter to the turbo, to the intercooler and to the manifold will be difficult to install because the space available is limited.
The project is going on and that’s the most important think right now.
Joćo
Old June 7th, 2011, 09:19   #12
JoaoT4
JoaoT4's Avatar
I’m doing an update to this conversion.
I have already done 15 000km on it and everything is working fine. The change I made on 5th gear ratio made a huge difference on RPM while cruising. With this engine I reduced the noise inside for more than 50%. Now I can speak with my soon on the back seat.
At 120km/h I can get 7.3 l/100km (33 MPG - us)
I installed the cruise control and tune it. I can drive at 120km/h with no problem even uphill. I can easy go to 140km/h.
My problem right now is the hot weather. I will install an AC and I started to pick up the parts I need. I bought the condenser, the evaporator and the expansion valve on ebay. I also have some AC tubes that I need. I hope to start to install the AC next week. I hope everything goes well as it did with the engine.
Joćo
VW 1302 (super beetle)
VW California Coach 1.9TDI (westfalia)
Old June 7th, 2011, 20:27   #13
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
So you didn't modify the oil pan at all?
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old June 8th, 2011, 02:20   #14
JoaoT4
JoaoT4's Avatar
No I didn't. I used the oil pan, the oil pickup tube and the dipstick from a VW T5 AXB engine. The angle isn't correct but since it's bigger I can put more oil in to compensate.
If you need to remove the oil pan you will need to remove the gearbox first, because of a hide bolt.
The ARG oil pan is too small.
The oil pans are in aluminum so they are hard to solder.
Joćo
Old February 10th, 2019, 08:29   #15
Fermounth
Joćo
This is for use with T4 4 cilinder oem engine mount , or direct use from engine block to t4 rubber mount?
I will do the conversión on mine with AGR but i have 2.4 AAB. I need to know how do you make the support.
Fermounth is offline   Reply With Quote
Page generated in 0.17572 seconds with 10 queries
[Output: 123.52 Kb. compressed to 102.07 Kb. by saving 21.45 Kb. (17.37%)]
