CortH
FS 2010-2014 volkswagen jetta sportwagen ecohitch
FS 2010-2014 VOLKSWAGEN JETTA SPORTWAGEN ECOHITCH Including Curt wiring harness. Comes with ALL hardware needed to install on your JSW.
The following information from the Torklift website, where I bought the hitch:
EcoHitch® for the 2010-2014 Volkswagen Jetta SportWagen. Made from high impact powder coated aircraft grade aluminum, stainless steel and steel.
Rated for 200 pounds tongue weight, 2,000 pounds towing weight
Part number: x7285 (1.25")
>Completely concealed design - only receiver is visible when installed
>100 percent bolt-on installation - no drilling required
>Engineered to meet stringent national SAE J684 towing safety standards
>Does not affect ground clearance
>Manufactured with high impact powder coat
>Material can include a qualified combination of aerospace grade aluminum, stainless steel or steel*
>Eco-friendly, made with recycled materials
>Lightweight
>Made in U.S.A
Here is info about the wiring harness from eTrailer:
2011 Volkswagen Jetta SportWagen Trailer Wiring
Curt Upgraded Circuit Protected Tail Light w Converter Hardwire Kit - 4 Pole End
Powered Converter
4 Flat connector
Code: 56146KIT
I paid $331 only a year ago. I will ship it to you for $250 from Madison, WI
Thanks for looking!
>Lightweight
>Made in U.S.A
Powered Converter
4 Flat connector
Code: 56146KIT
Thanks for looking!
