franklinstower
Airbag code: 01222
2004 Jetta wagon.
it says:
1 Fault Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180) 30-00 - Open or Short to Plus
any ideas of where I should start looking for the issue? Is the sensor under the seat or in the door. I know I need to disconnect the battery before I start doing anything. Do the sensors go bad or is it more likely a wire connector issue.
Paul
2004 Jetta wagon.
it says:
1 Fault Found:
Paul
