So I'm new here and hope this is the right place to post but I need help.
I have a 2002 Jetta 5 speed (auto converted) alh.
I had this car for a few months driving back and forth from Arkansas to new Mexico for work. I drove about 700 miles to work, didn't notice anything out of the norm. parked for 2 weeks like normal and when I went on days off it would crank but not start. I just changed the fuel filter, tried priming it, loosened a injector line and no fuel, so I had a mechanic change the IP and upgraded to an 11mm. I had them change the TB, rollers, pump with a 100,000 mile kit from Kermatdi. I got it back and it had the P1248 code. smoked A LOT more than normal and very, very sluggish on the bottom end, basically didn't make any power until 2,000 ish RPM.
I figured I needed to tune it for the larger pump so I drove about 1.5 hours then it lost all power, couldn't maintain any speed on flat road. so I pulled over to check fluids which were good, but noticed it idled rough and had a knock. I tried to limp it the last 10 miles since I was in the middle of nowhere, but it didn't have enough power to take off in first gear on level ground. mechanic told me I had two cracked injectors so I got sprint 520s from Kerma with the hot swap, mounted and balanced. that didn't fix anything.
from some quick reading on here, I'm thinking possibly case pressure too low and maybe hammer mod??? but I'm not throwing out the possibility that they didn't time it right from the start, but I had them double check and they said all their marks where still lined up.
I don't have VCDS.
Mechanics aren't familiar with TDI, they are oilfield mechanics, but I'm in Jal, NM for anyone who knows where that is, its literally nowhere lol.
I don't have VCDS.
