VCDS Scan as requested
This scan was ran before I made any changes. I haven't run a scan since.
Tuesday,11,October,2011,16:28:14:29128
VCDS Version: Beta 11.8.0
Data version: 20110831
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A32CC0xxxxx
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BP HW: 03L 907 309 S
Component: R4 2,0L EDC H21 2158
Revision: 71H21--- Serial number:
Coding: 001D0012042400000000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BP 004004
ROD: EV_ECM20TDI01103L906012BP.rod
VCID: 73C3ECF86CAF
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 054 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2806
Revision: 05351113 Serial number: 00001106291359
Coding: 0000020
VCID: 1605F56C5F9D
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: C54BC0F5492300FEA30B03E6921E0042A70000
VCID: 7BD3C4D844FF
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic H01 0102
Revision: 00001001
Coding: 0010001002
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1819FB545589
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 P HW: 5K0 937 085 P
Component: BCM PQ35 B+ 011 0047
Revision: BH011001
Coding: 6F200E1B902B08D408880001160004480071008640A00560648060000C70
VCID: 40A973346D99
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 060911 05 54 0403
Coding: 22300A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003END09BWZB
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_VW41.rod
VCID: EFCB60888087
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339 SW
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006YEJ0%
Coding: 30324D
Driver's Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 SW
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME23700342ZZZE
Passenger Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354 SW
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7E4B7060ZZZ0
Driver's Rear Airbag Crash Sensor:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 ASW
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME7F105312ZZZN
Passenger's Rear Airbag Crash Sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 ASW
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME1D4C5212ZZZU
Driver's Front Airbag Crash Sensor:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 ASW
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME75651B12ZZZW
Passenger's Front Airbag Crash Sensor:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 ASW
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME28461B12ZZZU
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110719300447
Coding: 088A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS_VW41.rod
VCID: 76C5D5EC7FDD
Multi-function steering wheel:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 DSW
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_VW41.rod
VCID: 1A1DE15CAB85
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 09081101290287
Coding: 461000
VCID: 38591BD43549
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1829227R07E605
Coding: 0000002
VCID: E3E31CB85C4F
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
VCID: EAFD719CBB65
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0002592572
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: DB932458643F
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 3C0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 290 3201
Revision: 00H20000
Shop #: WSC 01357 011 00200
VCID: 34412FE42921
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01030108
VCID: EFCB60888087
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591 SW
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 BSW
Component: Analoguhr 008 0002
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0002505793
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: DC9127446131
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 3C0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0018
Revision: -----17S Serial number: VWZ4Z7L3198773
Coding: 0500040004
VCID: 62ED99BCC355
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660464775
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_VW41.rod
VCID: 354712E0225B
End ---------------------------------------------------------------------
