mattyc5094
- Joined
- Dec 14, 2005
- Location
- Patterson N.Y.
- TDI
- 2006 jetta BRM,2000 Jetta ALH 2009 sportwagon tdi (totalled),1999.5golf tdi 1998 GOLF (4) RABBIT diesels, 81 Dasher diesel, 2005 DODGE CUMMINS
I have 2 -2006 tdi's with possibly two separate CCM issues. First 2006 has a battery drain issue overnight. This one I solved by jumping the fuse for module under hood to one that is powered up when key is on. Condition corrected for now.
Second 06 has front left signal light stays on all the time even when key is off and right front side doesn't work at all. I changed both headlights, checked all fuses, cleared all codes with VCDS and checked all coding compared to my other 06 and no change. Would the CCM cause only one front signal light to stay on and isolate other not to work at all? Hazard switch, dash indicators and rear signals work as intended. Dash shows light out warning. I ordered a used CCM on Ebay but not confident due to both my 06's have possibly bad CCM's and cant see one sitting in a scrap yard being ok. Can I install a newer CCM from a newer Jetta which maybe has an updated circuit? 1KO 959 433 AF is installed in both cars now, which other ones can be coded for my cars? BTW both cars have regular headlights and economy MFD
