Based on what research I've been able to do, I believe the belt that you can see when you're under the front of the car on the passenger side is the serpentine belt...correct?
The crankshaft seal has just been replaced on my car when the TB was changed. I'm seeing a reasonably small amount of oil leaking from the end of the oil pan that looks like it has a flange that connects to something in the area of the serpentine(?) belt.
Any help on where this leak might be coming from, assuming that a diagnosis could be made given the very limited info I've provided, would be greatly appreciated.
