fastcar4re
This morning I installed a new VW dealer battery into my Passat. The car started as expected; however, I had a new, and still have, a steady thumping noise coming from the engine compartment (sounds like passenger side) that rises and falls with engine RPMs as soon as I start the engine. That sound was definitely not there before the battery replacement 1 day ago. Immediately after I replaced the battery I drove the car slowly down through my parking garage and at about 250 yards, the brakes failed completely. I bumped the car into neutral and pulled the handbrake slowly and came to a stop. The camshaft was replaced less than 20,000 miles ago. The maintenance is impeccable and done at the dealer. I don't cut corners. Any thoughts on what the thumping could be and could it be related to the brake failure. The brake pedal is like pressing on a brick; there is no travel in the pedal. Thanks again for any comments or suggestions.
