gintaras
- Joined
- Dec 4, 2001
- Location
- Hammond, IN
Tuned up the car(timing, belts, oil, air) when I got it 6000 miles ago (now has 116000), and ever since (don't know if it was happening before) I have been losing about 1qt/500 miles. Hmmmmm, where is this oil going????? someone suggested that the turbo seals may be going out, causing oil to be pushed past them, and into the intake tract, getting burned off during combustion. This makes sense to me because my PCV hoses are oil-soaked, and I took off the hose that leads from the turbo to the intercooler, and it too was oil soaked, I put my fingers in there, and they came out dripping with oil. Probably the turbo, right???
Well, just about 200 miles ago, I have noticed a surging/hesitation/struggle between 3000 and 4000 rpm's under load, I tried new injectors and a fresh fuel filter, but it still persists. So maybe that also could be the cause of a turbo going bad??? Further suggesting bad seals is a coat of oil on the intake just behind the metal-to-rubber turbo output joint, suggesting that under boost, a fine mist of oil is being pushed pat the clamps and onto the intake.
Now, it doesn't hesitate without load, if I am in neutral, it will go to 4000 rpm's nice and smooth, but under load is where I get the hesitation at ~3200-4000 rpm. ANyone have any clues??????
