Old June 4th, 2018, 19:24   #1
1975 Kombi
Default AAZ that has sat for a long time
I'm trying to revive an AAZ that has 50,000k on it but has sat for 5 years. It turns over and was not seized but just spins with no kick. So I need advice on what to check and what to try to get this thing firing again.
What I have checked.
There is power to the solenoid at the injection pump.
There is power to the glow plug rail but glow plugs maybe toast.
The fuel is old and could be a problem. I might try fresh fuel from a can.
Not sure what type of spray to use to get it to fire. Ether? I have heard WD40 will work?
I will pull the injectors to check and do a compression check. I will pull the glow plugs and test them. I'm not sure if the old diesel fuel would have turned to sludge and clogged the injection pump.
Any help would be appreciated. Thanks
1975 Kombi is offline   Reply With Quote
Old June 4th, 2018, 19:32   #2
ToddA1
Fuel Economy: Dismal
You’re trying to burn 5yo fuel? I have a feeling the vanes in the pump are seized. Were you getting smoke at the tailpipe?
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Old June 4th, 2018, 19:32   #3
Vince Waldon
Vince Waldon's Avatar
Some suggestions:
1) DON'T use starter fluid... it's very hard on engines with glow plugs, and really doesn't tell you much anyways other than that you may have a little compression left.
2) DO make sure your glow plugs are working... the AAZ is an IDI engine and needs 'em to start, even in the summer.
3) DO drain and then refill the IP with fresh fuel and make sure it's primed by loosening the nut at the top of each injector a bit and then crank (have a rag, fire extinquisher handy etc etc). You'll need to get the internal vane pump working, and making sure it's full of fresh fuel plus providing a way for the air to get out will help save your battery and starter.
4) DO make sure you've a strong battery... IDI engines need to turn over fast to generate heat. I sometimes will jumper to a running car just to make sure I don't run out of electrons.
5) DO give your starter breaks while cranking so that it cools off. 20 seconds of cranking followed by a couple minutes of cooling will save you from needing a new starter soon.
Working glow plugs and a primed IP and she should run... AAZs are tough to kill.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old June 4th, 2018, 19:35   #4
1975 Kombi
Tank is like 3/4 full. lol I will have to find a way to get rid of the diesel.
Old June 4th, 2018, 19:52   #5
Vince Waldon
If you can rig up a temporary jerry can to run into the pump it's a great way to go... you know you will be using fresh diesel *and* it will be much easier to get the IP to prime with gravity helping.
Speaking of fuel, replacing the fuel filter is probably a must-have too... it will not have aged well and could well be clogged with algae at this point.
Fingers crossed for you!!
Old June 4th, 2018, 20:07   #6
Steve Addy
TDI(s): 97 Mk3
I'd agree with the other comments about a 5 yo idle engine probably not having a good IP. There tends to be some residual gunk in there that causes problems. You can kind of check that by removing the exposed side cover on the IP down at the timing advance device to see if it's rusty down there.
If you do try and start it I would definitely replace the fuel filter and use a vacuum pump to pull clean new fuel through the IP. I know others talk about algae but I have never seen an algae contamination in all my years with diesel. I think perhaps in areas of the country where there's no freeze cycle for winter it might happen but even in Iowa having had diesel for much of my adult life I've not seen it.
Good luck
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old June 4th, 2018, 20:55   #7
1975 Kombi
I will give all the suggestions a try tomorrow and report back. I will for sure short cut the fuel line to a fresh can of diesel and loosen the nuts on the fuel lines at the injectors. Will also check glow plug function. Thanks everyone.
Old June 6th, 2018, 16:30   #8
1975 Kombi
OK I short cut the supply of diesel to a Jerry can and bled the injection lines at the injectors which were dry and the puppy fired up. It took 30 mins of playing the 20 second games and waiting 10 mins for the starter to cool down but she runs very well. Seems to idle a touch high for me but a steady idle at 1100rpms.
Old June 6th, 2018, 17:29   #9
Vince Waldon
Excellent!!!!
If you don't mind one more suggestion: the very first thing you might want to do is to carefully watch the harmonic damper (big pulley attached to the crank)... from underneath the car... while the engine is running. You're looking for side-to-side wobble.
I mention this because if you see any significant wobble it will strongly suggest that the engine has fallen prey to the single most common AAZ issue: a worn crank snout.
When the crank snout wears the pulley wobbles but also the crank/cam timing starts to wander as the engine pounds away on the snout, and before long pistons meet valves with a bang.
To fix the engine needs to come out and good AAZ cranks are getting hard to come by... good issue to eliminate before you spend any further time or money?
Old June 6th, 2018, 18:36   #10
ToddA1
Great news!
If the crank nose is worn, why not have the crank modded to run the TDI sprocket? I can’t see cutting the flat, too much of a challenge for a competent machine shop.
-Todd
'97 B4: Stock
Rabbit build
Old June 7th, 2018, 05:15   #11
1975 Kombi
I will check for wobble. But if there is NO wobble is there anything that can be done to keep it that way?
Should I add some type of injector cleaner to my jerry can to do a direct clean?
Is there anyway to save the 10 year old diesel in the tank?
Old June 7th, 2018, 05:58   #12
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
As above, the snout on the AAZ cranks is a weak design.
Best option is to remove the crank and machine it to the D-shaped later style and use a ALH/AHU crank pulley.
Failing that, it would be wise to check and replace the crank pulley you have now, using a new crank bolt torqued to spec.
Also, install a later style one-way alternator pulley to relieve the inertial forces on the crank pulley from the alternator rotor.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old June 7th, 2018, 10:57   #13
0die
I wouldn't both draining the tank just yet...see if it will run off the tank, the old diesel might still be fine...just burn thru that tank with some algaecide or other diesel additive/cleaner....all the way thru til it starves of fuel so it's almost all flushed out...then add a tank of fresh fuel to rinse the tank and then a new filter...
I picked up an old abandoned Mercedes that had been sitting at the navy impound lot for several years...all it took was a new battery and several starter cycles (with cool downs) to prime the pump and it fired up and ran smooth....
1996 Passat wagon TDI
assorted gas powered crap and motorcycles
RIP...countless Mercedes, Isuzu and other random diesels
0die is offline   Reply With Quote
Old June 7th, 2018, 17:00   #14
1975 Kombi
Just a long shot but does anyone have a pic of the vacuum line schematic for a 1993 AAZ Passat?? Seems most of the lines from the breather box out have been removed or fallen off. lol
Old June 7th, 2018, 18:24   #15
Vince Waldon
https://workshop-manuals.com/volkswa...e_connections/
Sat Too Long? Stealth TDI VW MKIII-A3/B4 TDIs 14 July 18th, 2015 14:55
sat morning wrench time. grizzlydiesel TDI 101 5 April 30th, 2009 17:45
EuroCrave August 16th 2008(SAT) -Long Beach Eurocrave West Coast Canada/USA 0 August 13th, 2008 23:29
Long Island GTG This Sat. Nov. 6th AlanTDI Eastern USA 0 November 3rd, 2004 16:51
1st time buyer - Delivery on Sat, suggestions? Shawsie VW MKIV-A4 TDIs (VE and PD) 5 May 26th, 2004 20:39
Page generated in 0.16188 seconds with 11 queries
[Output: 127.53 Kb. compressed to 105.96 Kb. by saving 21.57 Kb. (16.91%)]
