markitzero
I ordered up this fog light trim that has LEDs from amazon and installed today... required a bit of triming of the lower center grill but came out alright. The wiring has been secured below and brought up near the drivers side headlight. Three wires, power, ground, headlight trigger that reduces brightness 50%. Ground and the headlight 50% wire are easy. Where to get the power? First thought was to tap into the DRL light but I dont want the incandescent bulbs in the headlight housings on and if I pull them it will throw an bulb out error on the dash. Any creative ideas where to get switched power?
