buckhunter94
I have an 02 golf and at random times the TC will not lock back up after it kicks out. A little more common once its warm but seems to do it if you run it a little hard..I changed the valve body and harness because it was doing the same thing and started to not want to shift till about 5000rpm. That part seems to be fine now; but It will start showing the P0740 is pending if I clear it it will lock back up till its ran a little hard or going up hill and it kicks out. Any ideas? I've heard it could be the TC going bad
