Ive just got a Malone stage 3 tune. I was having under boost problems putting my car into limp mode. So I adjusted my new actuator and its now running at optimal boost. Now my problem is that i'm not building boost early enough.
Please check out this log of Actual vs Requested boost and let me know what you think the problem is. Could it be my n75 valve being faulty and it doesn't produce the vacuum needed to close the actuator and make boost? when testing my actuator with a mity vac the vein arm and actuator moved at the right vacuum pressure.
Thanks for all the help
