Old September 21st, 2018, 04:39   #1
mfortmann
TDI(s): 2006 Jetta
Default BRM with DSG Passenger CV Axl?
Please help! Driving home yesterday, I all of the sudden had an issue when I was coming to a stop sign. There was a clunk on the passenger side front wheel/transaxle, both at the time of coming to a complete stop (downshifting into 1st) and at initial acceleration. Now it happens every time I'm coming to a stop and then accelerating. What could this be? The shop I use doesn't usually intake new issues on Fridays. I want to make sure my car is at least safe to drive to the shop.
mfortmann is offline   Reply With Quote
Old September 21st, 2018, 14:26   #2
oilhammer's Avatar
Fuel Economy: fantastic
No idea until the car is up on a lift and checked out. If you are worried, have it towed.
www.cardocautomotive.com
Old September 22nd, 2018, 09:26   #3
mnbrown25
Open the hood and look at how the motor is sitting. If the passenger side of the motor is tilted down a bit, you may have a broken engine mount lug(s). This is how I found that my engine mount lug was broken. If that's not the issue, then bonus.
mnbrown25 is offline   Reply With Quote
Old September 23rd, 2018, 11:25   #4
Dominicdx
Fuel Economy: 40-45mpg 600-630 mi.
Did you find issue?
Dominicdx is offline   Reply With Quote
Old September 23rd, 2018, 12:58   #5
morpwr
Fuel Economy: 40-60
Default Check nolts
I had same situation. Got off Highway on off ramp. Came to a stop at lights then started to make clunking sound. Found bolts which hold the axle on had come out. They were torqued and with blue loctite. Car had been driven 120,000 kms since installation
morpwr is offline   Reply With Quote
Passenger (Left) side CV Boot Replacements flash9 VW MKIV-A4 TDIs (VE and PD) 5 March 28th, 2017 06:25
WTB: inner CV joint, passenger side, mk4, manual trans breakfasteatre Ontario 5 August 11th, 2013 18:46
WTB mk4 passenger side cv boot shroud FL/COtdi Private TDI Items for Sale/Wanted 1 December 19th, 2012 12:43
Axl Question RichDiesel Ontario 7 August 15th, 2009 08:40
my passenger axel inner cv joint bobby638 TDI 101 0 January 22nd, 2009 20:39
Page generated in 0.14433 seconds with 12 queries
[Output: 68.25 Kb. compressed to 60.50 Kb. by saving 7.75 Kb. (11.35%)]
