a_hudson@roadrunner.com
2000 Jetta A/C compressor only comes on when moving above 10 mph. off at idle. Car runs great no fault codes at all climatronic module no faults.
What started the issue: pulled dash to replaced heater core, evaporator core, expansion valve. Put all back together went to charge A/C unit and no compressor at idle. Put car on a charging machine and forced Freon into the system. Super cold when compressor is on, at idle A/C clutch will not engage. Hooked Vag-Com and HVAC system shows compressor off by “Missing Engine Speed Signal”. Car engine speed is perfect and the instrument cluster tach runs smooth. Replaced fan controller still no change.
Any Ideas? I'm guessing I must of forgot the speed sensor wire somewhere. Help
