Jetta4Dollars
- Joined
- Nov 23, 2008
- Location
- Louisville
- TDI
- 2003 TDI 1.9 Bosio 520 Sold 2011 TDI 2.0 sportswagon Buy Back VW 2013 Audi Q7 Prestige 20"
??Need HELP! why can't I get a response BAD MAF conditions with brand new MAF
Jetta 2003 243k miles. Owned since 129K, cleaned intake at 150K changed group 03 to reduce intake clogging. Installed Bosio PP520’s about 175k, replaced timing belt, accessories, and vacuum lines at 200k. The problem started about 10k ago, I have low power from 3k RPM and above. I have replaced the MAF with new Bosch from IDparts and the problem did not change. I have changed the N75 relay, MAP sensor and neither made any difference. I have verified the turbo vanes move with might Vac , the rod starts moving at 3lbs and continues to about 15-18 lbs. The car generates 25-28 lbs of vacuum at idle, mighty vac gauge I haven’t checked it while driving. I have recorded group 003 while under load in 3rd gear from 2800 RPM until 4000 RPM and the specified MAF is steady at 850 while the actual is bouncing around as the car pulses. The actual will briefly touch 950 at 2800 when I first hit 100% throttle then drops off to 650 max all the down to 430 while holding the throttle at 100%
