Hi there, i was just wondering if anyone has solved a problem of boost cutting out, or fuel.
i have put bigger nozzles on the injectors and ever since at just over 3000rpm in only 5th gear it cuts almost all power to the accerator pedal until i restart the engine then it goes back to normal. i have a BMC filter exhaust, egr bypass bigger piping and chip and it does give alot of boost with a small puff of smoke only briefly and revs free to 4500rpm never cut out before i fitted the bigger nozzles and why just in 5th gear??????.
many thanks..
many thanks..
