Evan Sussman
BEW Boost "sputtering", low power, possible camshaft issues
Greetings,
I've got a perplexing one. I think it may have be the result of a handful of contributing factors, or just a big coincidence.
The car is an '04 Jetta with about 130k miles.
I'm about 2 months into this one... Car was working fine as far as I could tell. My wife drove it while following me in a work truck to the mechanic. I noticed unusual smoke from the car in my rear view mirror. She doesn't have the lead foot that I have.
When I got in to drive home the car was very sluggish and smokey. Boost guage registered boost lower than normal. I have a tune by Kerma so 17-20 is to be expected as long as I watch for boost creep.
I have:
- checked for boost leaks (none apparent).
- checked MAF with VCDS and by unplugging (appears to be good).
- checked intake for clogging (not signifigant, though did clean EGR).
- checked for turbo play (there is movement radially but not enough to touch the housing, no signifigant axial play).
- bought a mitivac and determined the turbo actuator was leaking.
- replaced actuator with modified VNT-17 actuator. (adjusted on table to actuate between 3-18psig.
Test drove car. Boost was all over the place, had spikes into the high 20s. Gingerly limped the car back home.
- determined turbo vanes were sticky. removed turbo and cleaned thoroughly.
Test drove car. boost no longer spikes, but "stutters" as it moves through it's range. I don't have power like I should. By stutters I mean that the needle flutters by about 3 psi as it moves up and down. I can also build 5-8psi of boost at idle by revving the engine which I don't remember as normal.
Car was idling very rough around 1200 rpm, but that got almost entirely normal after I ran a can of diesel purge directly into the fuel lines at the fuel filter.
- looked at camshaft again, but closer and after I'd found pictures of a "bad" camshaft. There's a tiny bit of wear on the rocker arm lobe, but not any kind of indent like some pictures had. The valve lobes are worn so that maybe 1/2" from the apex does not have the chamfer on the edge anymore.
At this point the main symptoms are:
- loss of power
- boost flutters potentially into overboost (>20 psi) range if I keep my foot down.
Are those symptoms that could be caused by the cam alone at this point? or is there other diagnosis that I should do?
Thanks!
Greetings,
I have:
- loss of power
Thanks!
