dobeonguard
Are there any good direct replacements for the halogen low beams on the 2015 Golf TDI?
H15 bulb is the high beam & DRL. Lows are H7s.the original reflector housings are the problem. The screwy h15 bulb for high/ lows really limits what you can do with them. Ed,s headlights work pretty well and you can adjust low and high beam separately. The standard factory headlights are a disgrace.
Yes, but I would trade the increased performance of deAutokey's HID kit (vs. their LED kit) for the slightly less plug-and-play-ability. Price is the same. Also you get a choice of higher or lower color temp. with the HIDs compared to the 5500K of the LEDs.So deAutokey H7s are probably the best plug and play solution? It’s like I’m driving by candlelight when I get I to the Golf after driving my Outback Limited with LED headlights.
Yeah, Ed's with Morimoto 5k are amazing! Look fabulous and work VERY good.LEDs in a reflector housing are a viable option for someone on a tight budget that wants significant lighting improvement and doesn't expect laser-sharp definition/cutoff or super even light distribution. Or someone who needs an easy installation. HIDs in a reflector would be the next step up in performance (with the same caveats as LEDs) and a step down in installation ease. Of course, Bi-xenon projectors are the ultimate upgrade, but there is a legitimate middle ground here.
While I will be installing Ed's projectors eventually, I wanted a quickie temporary, modest improvement and installed what some consider the highest performing standard wattage halogen bulbs: Osram Night Breaker Laser Next Gen. They upped performance of the reflectors from virtually unsafe to barely acceptable . Even if someone considered the performance of this combo OK for a final solution (which I think few would), I expect these bulbs to last months, not years. When these go, in go Ed's.
