tdismithville
Hi there - I've had intermittent limp mode for a couple years now. I've replaced the N75 valve. Today I hooked up a Mity vac directly to the actuator and the rod moved freely and held vacuum at about 22-23 Hg. I then tried the same thing going from the N75 valve vacuum line down to the actuator and it held vacuum as well, and moved the actuator rod. I replaced the connector that goes to the actuator, as well as the 3 wires that go into it. The yellow wire was definitely broken clean through. The purple wire was good. The green wire was half way through. The green wire though seemed to be corroded, even back as far as about 1.5 feet where I cut and spliced it. I cleaned it up where I cut it, before I soldered it to the repair wire. Is this green wire still my issue, or can you recommend where I should go from here? Any help/advice would be greatly appreciated. Scott
