Hi all,
So please lend me some advice, fellow TDI-enthusiasts, about turbos at high altitudes.
As many know, my turbo blew chunks last month. Literally - when I dropped the engine cover, the wheel fell on my head along with hunks of metal that were destroyed beyond recognition.
We can speculate why, but I'm mostly concerned with putting something reliable back together again. I see a couple of options:
1. Buy a new stock turbo for $1K and remove the Upsolute programming - just to be safe. Cross fingers! But most of the other blown turbos in Utah weren't chipped either! So am I any safer?
2. Buy a bigger turbo wheel for $1.5K and leave the upsolute programming in place. Cross fingers! There is much less data to draw upon when considering the reliability of this option.
I'd like input from you fellow TDI enthusiasts as to which you believe would be more reliable in the long run. If I could understand the cause for failure in my turbo, I'd better understand how to avoid it next time.
Was the EGT too high? I doubt EGT since my wheel failed while at near-idle, after a very lazy trip on the freeway. Would a bigger wheel reduce EGT at all? Probably increase it, right?
Was it excessive wheel RPMs? Of course a bigger wheel would spin slower - so that would be safer, right? Or is the bigger wheel heavier anyway, negating this advantage?
Was there a computer (ECU) malfunction that caused a sudden catastrophic failure? Can the turbo physically be instruced to overspin to oblivion as just a freak accident?
If I had a bigger wheel, wouldn't the ECU continue to adjust the boost pressure regardless of the turbo's size and capabilities? I mean, if all else is identical, I'd generate the same boost pressure at the same altitudes I always have - just at a lower wheel RPM, right? So this would be safe at sea level too, right? Any opinions on this assumption?
Input along these lines is appreciated. Thanks for the support.
Aaron
Aaron
