muddyboots
Hi all
Greetings from the UK Long time member, very infrequent poster...
I have a 2011 Skoda Yeti, with the CR170 CFJA engine. Just covered 50k miles.
I've recently had a Stage 1 tune (est 205-210bhp) from a well known UK tuning company, and have been logging DPF soot loadings with VCDS - both in standard and Stage 1 tune.
I usually do two 40mile journeys each day. Half of each journey is open road, 60+mph, the other half is slower urban traffic.
Was wondering if my findings are typical, or whether I possibly have an issue with the car.
Standard tune:
The "Calculated Soot" value rises slowly, and takes around ~250-300 miles to reach 16g, at which point a regen is triggered.
The "Measured Soot" value tends to rise on average by maybe 2g per journey; at points during the journey it will rise a little more than this, but other times it will reduce slightly when I'm cruising fast enough for DPF exit temp to be over ~310ºC.
In summary, regens tend to be triggered by the rise of the Calculated Soot value, every 250-300 miles.
Stage 1 tune:
The "Calculated Soot" value rises similarly to standard tune, maybe a little faster if I really use the power, but generally the same.
The "Measured Soot" value rises constantly and fairly quickly. In the course of the same 40 mile journey above, it will rise by maybe 12-14g. At 16g it will trigger regen. The levels rise during normal, light-throttle cruising as well as full power use.
In summary, regens are triggered by the quick rise of the Measured Soot value, every 60-80 miles.
I think the soot loading with Stage 1 tune is excessive, however this is a standard CR170 Stage 1 tune from a very well regarded company with plenty of happy customers; I've logged requested vs. actual boost & airflow for them over a full-throttle run in 4th gear and they think everything looks in order, they've double checked the map too.
So I'm wondering if there is some underlying issue with my car ?
Does the soot loading behaviour of the standard tune sound normal ?
Any thoughts or suggestions of things I can check/log would be very welcome.
Standard tune:
Stage 1 tune:
