Old October 26th, 2019, 13:27   #1
dillenger1
dillenger1's Avatar
TDI(s): 2015 gsw tdi
Fuel Economy: 43
Default opinions on billet cams
Is it true that the billet colt cams have solve premature wear issues in the PD?
I vaguely remember watching a dark side video where he said they changed the profile on their cam to eliminate wear.was wondering if that's been incorporated into the colt design
2015 golf sportwagon
Kerma stage 1
Dsg stage 1
dillenger1 is offline   Reply With Quote
Old October 26th, 2019, 13:28   #2
Nero Morg
Nero Morg's Avatar
It helps, frank also makes a comparable one that's better on the wallet.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is online now   Reply With Quote
Old October 26th, 2019, 14:39   #3
Yourbuddysatin
Fuel Economy: 32-35mpg
The stock cams are iron so they end up flattening and chewing thru the lifters. A friend and I just replaced his cam and buckets. Oil sample showed lots of iron in it. Low and behold all the lobs but 2 were sharp and 1 bucket was almost completely chewed thru. Not a bad job though. Can’t beat the kit from dark side either.
Yourbuddysatin is offline   Reply With Quote
Old October 26th, 2019, 16:10   #4
dillenger1
dillenger1's Avatar
Fuel Economy: 43
Originally Posted by Yourbuddysatin View Post
The stock cams are iron so they end up flattening and chewing thru the lifters. A friend and I just replaced his cam and buckets. Oil sample showed lots of iron in it. Low and behold all the lobs but 2 were sharp and 1 bucket was almost completely chewed thru. Not a bad job though. Canít beat the kit from dark side either.
their performance cam requires injection timing change?
Kerma stage 1
Dsg stage 1
Old October 26th, 2019, 16:44   #5
dillenger1
dillenger1's Avatar
Fuel Economy: 43
frank?
Kerma stage 1
Dsg stage 1
Old October 26th, 2019, 17:30   #6
ToxicDoc
TDI(s): 2001 Jetta
Originally Posted by dillenger1 View Post
frank?
Frank06, a member here who is a pro, does head repair, sources high-quality injectors, in addition to running his shop.
ToxicDoc is offline   Reply With Quote
Old October 26th, 2019, 17:39   #7
Nero Morg
Nero Morg's Avatar
I'd like to quote:
Originally Posted by loganbmx4gt View Post
A God send to the VW/TDI community:
http://forums.tdiclub.com/member.php?u=31923
Old October 27th, 2019, 05:54   #8
Yourbuddysatin
The cam was a hair out of spec so we just had to knock it back in a tad.
Old October 27th, 2019, 08:55   #9
dillenger1
dillenger1's Avatar
Fuel Economy: 43
the dark side site claims their cam requires a change to the injection timing.Did you do their software change with it?
Kerma stage 1
Dsg stage 1
Old October 27th, 2019, 09:18   #10
Yourbuddysatin
Oh I’m sorry I didn’t know they made a performance cam also. We only put the stock size cam back in.
Old November 5th, 2019, 16:09   #11
adjat84th
adjat84th's Avatar
Assuming this is going in a PD?
Seeing the vehicle in your signature is a bit confusing.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old November 5th, 2019, 17:21   #12
dillenger1
dillenger1's Avatar
Fuel Economy: 43
yes bhw
Kerma stage 1
Dsg stage 1
Old November 5th, 2019, 18:06   #13
Yourbuddysatin
I didn’t think BHW had cam problems??
Old November 5th, 2019, 18:48   #14
Nero Morg
Nero Morg's Avatar
I didnít think BHW had cam problems??
They can if the wrong oil is used, it's just less of an issue on the BHW than the BEW did.
Old November 5th, 2019, 21:54   #15
Yourbuddysatin
Thanks! Good to know
New Billet Colt Cams TDIclub special at kermaTDI VailPowder Vendor & GroupBuy items for sale 63 June 3rd, 2011 09:09
New Billet Colt Cams from kermaTDI VailPowder Vendor & GroupBuy items for sale 28 February 27th, 2011 00:49
Page generated in 0.17471 seconds with 11 queries
[Output: 125.51 Kb. compressed to 103.99 Kb. by saving 21.53 Kb. (17.15%)]
