Old June 14th, 2018, 13:26   #16
Dieselkraut
TDI(s): 2011 TDI 6MT
Got on the phone with the dealer:
According to TSB - 2035641-3 No Mesh Air Filter shall be used as it can cause MAF to malfunction.
No Error code was found that calls a faulty MAF however they performed different measurements with the OLD K&N and original MAF and got a "Readout"
Then they replaced the MAF and new VW OEM Filter and got a different "Readout"
Therefore they blame it on the K&N filter.
I told them to move fwd and replace both, my cost $288
It should be VW's responsibility to inform consumers NOT to replace the Air filter with a Mesh filter and that it is NOT covered under warranty!
Can anybody look up TSB - 2035641-3 I cant seem to find it.
Dieselkraut is offline   Reply With Quote
Old June 14th, 2018, 15:18   #17
MichaelB
Fuel Economy: very good
It has never been any carmakers responsibility to warn you against using specific non-OE parts. That is the responsibility of the non-OE part manufacturer. Many owners manuals state "only use genuine manufactures parts" and that covers a lot of ground. If for say you replace the OE shocks with aftermarket and you break a suspension component it will not be covered under warranty.
Manufacturers set a spec for the part or fluid (oil etc). If you choose to use non 507 spec oil and your dpf has a shortened lifespan that is your problem, not VW's All being said the manufacturer has to prove that the non-OE part caused harm. Which in this case I think they did. Take your battle to K&N, not VW.
MichaelB is offline   Reply With Quote
Old June 14th, 2018, 15:59   #18
Dieselkraut
Did you know that VW with what you said is then in breach of the Magnuson-Moss Warranty Act
FTC Validates Right to Install Aftermarket Parts
“Under the Magnuson-Moss Warranty Act, the warranty cannot be conditioned to a specific brand of parts, services or vehicle modifications unless those parts or services are provided free of charge.”
https://www.sema.org/sema-enews/2011/01/ftc-validates-right-to-install-aftermarket-parts
Old June 14th, 2018, 16:10   #19
MichaelB
No, it didn't Mag-Moss Warranty does not cover aftermarket parts that are not of the OE Manufacturer spec
If said aftermarket part is not to OE spec, for example, an aftermarket tune that is not to VW spec it is in no way covered by Magg-Moss..Lowering springs, aftermarket exhaust and on an on it goes have no Magg-Moss protection. Now if you had used an aftermarket paper filter made to OE spec you would have a case.
Many aftermarket part suppiers are also OEM suppiers. K&N is not. All Mag-Moss states is that you don't have to buy the part from the original manufacturer.
Old June 14th, 2018, 17:29   #20
Dieselkraut
Please point me to where this is written?
Will using ‘aftermarket’ parts void my warranty?
No. An ‘aftermarket’ part is a part made by a company other than the vehicle manufacturer or the
original equipment manufacturer. Simply using an aftermarket part does not void your warranty.
The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny
coverage under the warranty simply because you used an aftermarket part. Still, if it turns out that
the aftermarket part was itself defective or wasn’t installed correctly, and it causes damage to another
part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for
that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the
aftermarket equipment caused the need for repairs before denying warranty coverage.
A TSB is NOT proof of fault, its a mere recommended steps and procedures for repairing vehicles.
PROOF would be the ACTUAL Fault code for the MAF! And they don't have that. (i.e. P0101 calls for malfunctioning MAF)
I thank you for your feedback and replies, don't take it personal please. I value everyones feedback and opinion. At the same token, I NEED to see PROOF before shelling out $$$
Old June 14th, 2018, 17:44   #21
MichaelB
Are you a Representative / Agent / Employee of VW or VW of America? Or a Representative / Agent / Employee of any other car manufacturer?
FYI: I'm a attorney at law.
Hell no!!!!!!!!..........I'm a retired manufacturing engineer from GKN Sinter Metals. My main product line was the production of Main Bearing Caps for GM, Chrysler, Ford, Honda, Mazda, and Nisson. I went on to play a major role in managing the preventative maintenance program for an aluminum foundry (Pace Ind). I bought all kinds of parts for diecast machines so I know a bit about Mag-Morr warranty. Now I'm just a retired person of reasonable intelligence that drives a VW Passat. Your an attorney at law so is my stepdaughter and she has no clue about the Mag-Mor. Go ahead sue VW for not having a preemptive warning to the consumer about K&N air filters and $288.00. I wish you well. I'm sure you will have to use K&N as a key witness....good luck with that. They already told you they would cough up the cost of your MAF sensor, that is the easy way out for them and satisfy the customer without court action. Too many smart ass attorneys in this world anyway. Have a great day.
Old June 14th, 2018, 17:48   #22
Dieselkraut
Essentially per the TSB - 2035641-3
I have a copy of it (courtesey of K&N) it states "... Only use factory Airfilters. ...The use of after market Airfilters is not supported..... "
Therefore under the Magnuson-Moss Warranty Act the FTC has ruled
Essentially VW MUST provide FREE Airfilters while under this NEW Warranty!
Old June 14th, 2018, 17:53   #23
Lightflyer1
Lightflyer1's Avatar
The dealer can say not covered all the way until you get to court and get a judgement against them. Good luck with that. You are never going to see proof from the dealer, VW or K&N. More than likely you won't even be able to find a lawyer to take the case. They will just laugh at you and tell you to pay the $288 and sop doing that.
Old June 14th, 2018, 18:00   #24
MichaelB
You missed a bit here he sez he is a lawyer so I guess his time is worth $288.00.
Edit if diesetkraut had done his homework in this community he would not be in this sinking boat in the first place.
Old June 14th, 2018, 18:04   #25
MichaelB
Those 10 dollar air filters are certainly not gonna break VW's bank! Keep pursuing' it. They will be doing you a favor by not letting you allow all that crap that a K&N allows to enter your intake.
Old June 14th, 2018, 18:11   #26
Dieselkraut
I like that if they admit to providing FREE Airfilters during the warranty period.
And yes the $288 is worth it as I am a attorney taking VW to court and its not just for the $288 there is a LOT MORE this is just another discovery AFTER ALL the modifications VW did.
Old June 14th, 2018, 18:46   #27
MichaelB
Maybe you can get a little pain and suffering too.
Old June 14th, 2018, 19:00   #28
MichaelB
Factory recommendation is every 60k you might get one
Old June 14th, 2018, 19:06   #29
MichaelB
I guess your time ain't worth nothin' I could spend that on a dinner and a stage show for two easy and never look back.
Old June 14th, 2018, 21:56   #30
MichaelB
NEW: Call from VW Quote: Need to replace EGR and DPF (under warranty)
Any input / advise? Thanks
Here is the biggie according to that statement VW will replace your EGR and DPF. So now you are quibbling about the K&N filter and MAF. Do you know what that is worth? Way more than your 288 buck MAF sensor. Have a nice life. Buy a different car.........say Honda and put a K&N air filter so you can save a couple of bucks.
alh m-Tdi marinisation to match Mercruiser Gen1 drive iddhi TDI Conversions 254 July 29th, 2019 09:56
WTB Gen1 3.0 Q7 or Cayenne will pay VW money CleanDieselTD$ TDI Cars for Sale/Wanted 0 July 7th, 2017 13:45
Post FIX MPG ddorrer Dieselgate - VW Group Emission Scandal 18 March 9th, 2017 06:48
P2002 mil code sandmansans VW MKVI-A6 Jetta Sedan (~ 2011+) 11 November 11th, 2016 05:12
2009 Jetta TDI P2002 Code MIL On Help TDiTucson VW MKV-A5 Golf/Jettas 5 May 29th, 2014 15:32
Page generated in 0.17822 seconds with 11 queries
[Output: 140.03 Kb. compressed to 118.17 Kb. by saving 21.86 Kb. (15.61%)]
