Old November 14th, 2017, 09:18   #16
bhodgkiss
simply amazing!
You have some serious fab skills. How have you welded the pipework? It looks seamless
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old November 14th, 2017, 10:57   #17
Machineman
Originally Posted by bhodgkiss View Post
simply amazing!
thanks i am a bit of a perfectionist lol pipe work has been all tig welded
Machineman is offline   Reply With Quote
Old November 14th, 2017, 14:51   #18
1.4TDI PD
really nice can"t wait for more pictures of the build.
1.4TDI PD is offline   Reply With Quote
Old November 14th, 2017, 15:17   #19
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Originally Posted by Machineman View Post
... I'm running a tdo4 13t high pressure Turbo had a TD06 20g low pressure... I have about 900 CFM of air to play with so we'll see where that takes me.
I don't know how you did the arithmetic to arrive at 900 CFM, but if the turbos are connected in series, you can't simply sum the CFMs of the HP and LP. The total max CFM is instead only that of the LP, that is, according to the below, closer to 600 CFM.
Not a knock, really - 600 CFM would still support about 400 HP in a TDI, which is more than you will likely actually achieve, but for the sake of correctness, 400 HP is more intellectually honest than 600 HP implied from the 900 CFM figure.
Love the fab work!
Old November 14th, 2017, 17:57   #20
Machineman
Thanks for chiming in I guess I was just assuming that's how it worked someone I know told me that's how it worked but I wondered myself if they were true or not irregardless 640 CFM is alot of air for a 2l tdi thanks for posting the compressor Maps!
Old November 14th, 2017, 18:02   #21
Machineman
Also based on some of the things I read people have said that the high pressure turbo helps to create flow as well I wouldn't assume that they're both added together but there is some sort of factor involved
Old November 14th, 2017, 18:12   #22
[486]
TDI(s): 02 golf ALH
Everything's so shiny!
I can't even get v-bands to seal under muffler pressure, much less EMP, hah.
[486] is offline   Reply With Quote
Old November 14th, 2017, 18:17   #23
[486]
TDI(s): 02 golf ALH
Think of the HP turbo and engine just as a larger engine that the LP turbo breathes into (and receives gasses from)
you might be thinking of how pressure ratios multiply when in series, where when you're running PR of 2 across both compressors you see 14.5 psig in interstage, then 43.5psig in intake manifold
Old November 14th, 2017, 19:08   #24
Machineman
I guess we'll see what happens
Old November 14th, 2017, 19:08   #25
Machineman
Eventually I think the low pressure will get upgraded to a 25g and the high pressure will get upgraded to a 19T
Old November 15th, 2017, 07:29   #26
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
Very nice fab work. Look forward to seeing how it comes together.
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Old November 15th, 2017, 07:40   #27
Machineman
The trick with v bands is to keep everything Superflat that's why I machine everything after welding I do strongly agree though v band can be a nuisance
Old November 16th, 2017, 07:58   #28
Machineman
anonymous image hosting
Old November 16th, 2017, 07:59   #29
Machineman
I've been working on the intercooler it's a lot of work I started out as a bare core there's not a lot of room on these B6 platforms I figured I would go custom the core is rated for 520 horse it's a good quality high density
Old November 16th, 2017, 23:18   #30
Machineman
Intercooler done
Need advice on compound turbo build Mahliloltdi TDI Power Enhancements 25 June 16th, 2017 22:03
I want to build a B6 S4 avant Quattro 6speed TDI. Possible? Celco TDI Conversions 2 March 22nd, 2016 13:54
Just another compound build.... fouckhest TDI Power Enhancements 574 December 27th, 2014 14:29
BEW into B6 S4 nitec TDI Conversions 3 October 26th, 2012 10:17
Audi A4 B6 Avant 130 Sport -> S4 project Phill Other TDI/Diesel Picture Gallery 2 October 13th, 2012 15:06
Page generated in 0.18186 seconds with 11 queries
[Output: 127.48 Kb. compressed to 106.28 Kb. by saving 21.20 Kb. (16.63%)]
