Old October 30th, 2015, 11:33   #1
Mopar-VW-Dieselman
Mopar-VW-Dieselman's Avatar
Default '02 ALH with CEL, VCDS ODB2 not connecting. HELP!
I have an '02 Jetta ALH with a CEL.
It started after I received a low coolant light. I added VW coolant & distilled water (50/50) to reservoir and low coolant light went out. About 3 miles down the road I received a CEL.
I "tried" to connect VCSD to OBD2, but received a connection error. I tried several times, same issue. I used same cable and laptop on '97 Passat TDI and had no problem connecting and running a diagnostic, so I know the VCSD cable and laptop USB connections are good.
Any thoughts other than a VW dealer to resolve the issue. Maybe something I can check?
I took a look under the dash and did not see any obvious wire or other connection problems.
I have a job interview coming up Monday or Tuesday and need it fixed. I'd hate to have it quit on me on the way to an interview (not a good thing). This is the first time I've ever had an issue with the VCDS and OBD2 not connecting.
Any recommendations would be greatly appreciated.
Mopar-VW-Dieselman is offline   Reply With Quote
Old October 30th, 2015, 11:41   #2
UhOh
UhOh's Avatar
Have you ever been able to get this combo working on this car? If so, when was the last time (and what has changed since)?
Might be worth a shot to disconnect the battery cables and touch them together (to discharge your electrical system).
Old October 30th, 2015, 11:43   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Check relay 109, re-seat it, If it's black get a new one.
Check fuses.
Any add on wiring?
Does the little light on the VCDS light (if applicable)?
Do you have the latest software (it should still connect)?
Back in the early days there were a lot of discussions on Coolant Migration. The coolant level sensor could crack and fluid would wick into the wire looms, real bad news. Hope it's not that.
Old October 30th, 2015, 11:57   #4
Mopar-VW-Dieselman
Yes, I've connected several times over the past several years. Only change was the "low coolant" light and adding coolant/distilled water (50/50 mix)
Check fuses.
Any add on wiring?
I will check the fuses. Nothing added to car for over 140,000 miles and have made connection with this laptop and VCDS cable multiple times. I do have the latest VCDS software installed too. No the light on the VCDS does not come on. Car starts and runs just fine, so I don't think it's the 109 relay, but I'll take a look at it and re-seat it.
Old October 30th, 2015, 12:06   #5
UhOh
UhOh's Avatar
Peek inside your wiring loom coming from the coolant reservoir tank and make sure it's not wet there. I think that I, and Bob, would feel better knowing that there's NOT that nasty coolant migration issue happening!
Old October 30th, 2015, 12:29   #6
Mopar-VW-Dieselman
Good idea, I'll check that as well. I did find a burned out 7.5 amp fuse. The "small size". I have a bunch of the standard size replacements, just not the small ones. My wife went to get a box of various amp small fuses. I hope that's the culprit. I'ts from space #12 if that helps any of you out there.
When my wife gets back, I'll be off line to test VCSD. This laptop is in a docking station and the WiFi doesn't work in the garage.
Old October 30th, 2015, 12:40   #7
mxracer291
mxracer291's Avatar
Fuel Economy: Best - 52/Avg. - 45
You didn't happen to install an aftermarket radio did you?
Northern Illinois TDI
(815)291-3047
https://www.facebook.com/NorthernIllinoisTDI
mxracer291 is offline   Reply With Quote
Old October 30th, 2015, 12:46   #8
Mopar-VW-Dieselman
Good question. Nope!
Stock Monsoon sound system!
Old October 30th, 2015, 12:54   #9
JB05
Fuel Economy: 43/41/40
My old lap top would not connect on its battery power alone. I had to plug into an outside source of electricity.
JB05 is offline   Reply With Quote
Old October 30th, 2015, 13:08   #10
Mopar-VW-Dieselman
Thanks a million UhOh and BobnOH.
I replaced the 7.5 amp fuse and the VCDS connected just fine.
Error: 16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-00 - Implausible Signal
I cleared the code and drove it around the block and it didn't come back on. I'll look more into it later, I have a business call in less than 1/2 hour.
I checked the wire loom and connector. BONE DRY. BUT I did add some DIELECTRIC to the connection to help prevent any other issues in the future.
When I get back to it in a few hours and drive it a bit more, I'll update you all.
Thanks again UhOh and BobnOH.
Old October 31st, 2015, 13:57   #11
Mopar-VW-Dieselman
....just a little update....
I put about 100 miles on the car yesterday, still no problems.
I connected the VCDS just fine this morning and ran a diag. on it, just in case there was still a problem lurking without a CEL.
Everything just fine!
Old November 1st, 2015, 19:31   #12
UhOh
UhOh's Avatar
Excellent!
ALH Connecting Rod turbobuilder TDI Power Enhancements 16 September 12th, 2017 13:31
ALH Piston and Connecting Rod Siwel Private TDI Items for Sale/Wanted 1 November 9th, 2013 16:23
Steering wheel module not connecting VCDS blu_jet_92 VW MKVI-A6 Jetta Sedan (~ 2011+) 1 September 3rd, 2013 17:21
WTB ALH Connecting Rod ecorob Private TDI Items for Sale/Wanted 0 February 4th, 2013 22:22
FS: ALH Connecting Rod Itsnotme1988 Private TDI Items for Sale/Wanted 3 March 22nd, 2012 11:39
Page generated in 0.17015 seconds with 11 queries
[Output: 113.66 Kb. compressed to 95.93 Kb. by saving 17.72 Kb. (15.59%)]
