Old October 23rd, 2012, 15:45   #1
bzeien
bzeien's Avatar
Default BobZ's TDI Smyth G3F Beta #9 Build
I'm posting my build of Beta kit #9 for those interested in the Smyth Performance G3F mid-engine sports car conversion for the MkIV Jetta and 4-door MkIV Golf. My particular build began with a 2004 Jetta TDI (BEW, 5-spd) purchased specifically for this project.
I hope to help provide some small insight into the conversion process through the following time lapse videos and progress posts...
My Build Specifics:
BEW 1.9 TDI
Chrome journal replacement cam, slotted bearings and cap mods (Frank06)
Passat cast iron exhaust manifold ported to Darkside Developments GTB adapter (RyanP)
Garrett GTB2260VK (RyanP)
SDI Scroll intake (RyanP)
4-Bar MAP (RyanP)
Firad +80% (RyanP)
O2M EFF 6-Speed (RyanP)
Peloquin LSD (RyanP)
SB Stage II Silent Endurance clutch/pp
Audi TT front suspension/brakes in both front and rear
Type 20 long flow air/water intercooler (very low restriction, rated to 350HP)
General information for the Smyth Performance G3F is at:
https://www.facebook.com/SmythPerfor...06171216118819
Additional sites, posts and build info available at:
www.facebook.com/SmythPerformance
http://www.ffcars.com/forums/139-smyth-performance-g3f/
In the beginning...
What it will soon look like (ok, different wheels, color, etc., but you get the idea...). Re-purposed for some fun!:
bzeien is offline   Reply With Quote
Old October 23rd, 2012, 15:53   #2
bzeien
bzeien's Avatar
Step 1: Initial tear down...
http://www.youtube.com/watch?v=uUAUn1Fqpfo
Old October 23rd, 2012, 15:54   #3
bzeien
bzeien's Avatar
Step 2: Get out the SawzAll!
http://www.youtube.com/watch?v=7GGhGLfBW9I
Old October 23rd, 2012, 15:54   #4
bzeien
bzeien's Avatar
Step 3: Assembly begins!
http://www.youtube.com/watch?v=Hf82YozNDIg
Old October 23rd, 2012, 16:06   #5
bzeien
bzeien's Avatar
Saving this spot...
Old November 13th, 2012, 07:37   #6
bzeien
bzeien's Avatar
Working on my BEW upgrades: here are photos of the turbo/exhaust/intake setup. I'll need to mount it all to the engine to test fit and determine the placement of the support bracket for the AWIC. Firad +80% injectors have also been installed.
The gtb2260vk is mounted to a Passat manifold ported to a Darkside adapter plate, the AWIC will be supported with a fabricated bracket welded to the SDI intake. The total plumbing consisted of only two 180 degree elbows (2.25" and 2.5"). I'm keeping the SDI ASV; there's a thread with instructions to convert the wiring to my BEW harness.
Overall a fairly compact package.
I cut a mount in UHMWPE for the 4-bar MAP, here mounted on the SDI intake
Old November 13th, 2012, 17:25   #7
A5INKY
Fuel Economy: pretty good
Looking forward to watching this unfold. Great build plan and choices so far.
Any plan for head porting? Heavier duty pistons/rods/girdle? The PD100 bottom end is pretty stout by old ALH standards but with that turbo and those nozzles you have the potential to make that bottom end cry for mercy.
Can't wait for this to be done, should be a total beast!
A5INKY is offline   Reply With Quote
Old November 14th, 2012, 15:10   #8
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Kinda a waste of a perfectly good TDI, no? There's so many wrecked ones that would work fine for this.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is online now   Reply With Quote
Old November 14th, 2012, 18:25   #9
LexDube
I had that in mind too you could have paid less for a wrecked one it is sad for a perfectly good tdi a 2004 to add but otherwise it is a quite nice project
LexDube is offline   Reply With Quote
Old November 15th, 2012, 07:37   #10
bzeien
bzeien's Avatar
Thanks! Some porting may be in line next year, I'll see how the tune works out before deciding on lower end mods. Even with an LSD and the 275/35-18's I'll be running, maxing out the power with this turbo/injector combination will make it difficult to hook up.
Not a waste at all! This car was purchased with a bad engine; next stop junk yard. I rebuilt it, spent 30k miles driving it while fixing all of the other systems and now recycling it into something that's fun and I want to drive! With a $20K budget there isn't much available new that's actually fun to drive. Building my own car from an eight year old sedan rather than buying something new also saved countless tons of CO2 to produce that shiny new one.
A 60+ mpg mid-engine TDI convertible with 250+hp, 400#ft torque and air conditioning that works, reborn from a tired old sedan, for $20K = my kind of fun car!
Go Green, Go Fast
Old November 17th, 2012, 15:40   #11
bzeien
bzeien's Avatar
Here are the parts mounted on the BEW, in the chassis. Testing fit and mocking up mounting hardware. Viewed from the trunk area.
Old November 20th, 2012, 17:24   #12
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
Go Green, Go Fast
You rock, Bob!
manual_tranny is offline   Reply With Quote
Old December 4th, 2012, 10:02   #13
bzeien
bzeien's Avatar
AWIC mounting position is set, now to weld up those mounts
(photos coming soon)
Old December 8th, 2012, 08:01   #14
dieselfuel
That's going to be one screaming little ride when you get done with it. And around 60 mpg, to boot= win! win!
df
2003 Jetta TDI 200,000 mi. Horrible fuel milage? Check your thermostat: http://forums.tdiclub.com/showpost.p...49&postcount=7
dieselfuel is offline   Reply With Quote
Old December 25th, 2012, 09:14   #15
bzeien
bzeien's Avatar
To minimize the overall size of the intake/AWIC assembly I decided to eliminate mounts and weld the intercooler directly to the SDI scroll manifold (after shaving off the threaded mount on the manifold side of the AWIC). This gave some additional clearance between the AWIC and turbo hotside/exhaust piping. I'm fabricating a stainless heat shield to mount beneath the intercooler.
Smyth Performance at TDIFest in Ypsilanti this Saturday! manual_tranny TDIFest 2012 9 August 30th, 2012 16:07
Smyth rwd conversion E-Z Wood Upgrades (non TDI Engine related) 9 March 18th, 2012 15:35
Smyth Performance BgRedBrck TDI Power Enhancements 1 April 7th, 2010 06:40
VAG-COM beta 408.0-D available MOGolf OBD Scanners 8 August 22nd, 2004 10:12
VAG-COM Beta 402.3 is Now Available! wolfsburg_de OBD Scanners 5 February 24th, 2004 20:59
Page generated in 0.19696 seconds with 11 queries
[Output: 133.56 Kb. compressed to 111.28 Kb. by saving 22.28 Kb. (16.68%)]
