Old October 28th, 2019, 16:45   #781
PakProtector
Do any of you know the wheel specs on the PD160 turbo Darkside is selling? Bigger than a PD150?
https://www.darksidedevelopments.co....pra-pd160.html
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old October 29th, 2019, 03:26   #782
ryanp
ryanp's Avatar
cheers,
Douglas
The wheels are the same size but the turbine wheel is shaped differently for better flow so they usually make 5-10hp more.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old November 9th, 2019, 08:58   #783
Nekit
TDI(s): 2015 Golf
Does anyone know where I can get the exhaust flange for the turbo downpipe, or what its dimensions are? Making a custom exhaust for a conversion project. Using CJAA engine with CR140 turbo. Thanks
Nekit is offline   Reply With Quote
Old November 9th, 2019, 08:59   #784
Syncrogreg
I have these CNC stainless steel $70 a piece. Use stock vband.
Syncrogreg is offline   Reply With Quote
Old November 16th, 2019, 17:17   #785
Ley
TDI(s): 3.0 4.2
hi, anyone has gtb 1749vz internal specs?
Ley is offline   Reply With Quote
Page generated in 0.14141 seconds with 10 queries
[Output: 67.33 Kb. compressed to 59.52 Kb. by saving 7.81 Kb. (11.59%)]
