Old August 7th, 2015, 09:27   #1
boise outlaw
Default Jetta Wagon Jeep XJ Spring lift
I figured i'd post this here for any of you looking to lift your wagons. The 90's Jeep cherokee coil is the exact same size and thickness as the front coils in the VW, but are 18" overall length (stock is 14") and have 8 coils instead of 6. Eyelet and base width are identical. I used these front and rear. In the front I cut off 1 coil from the XJ spring because it was a little too stiff running the full length, the stock rear coils have two eyelets however the base is the perfect size to fit the width of the XJ coil.
Sits 2" higher then stock, no other modifications necessary but will max out your shock in the rear. Will need a spring compressor to stuff them in the front but would be much easier with a bench-type compressor like mechanics have. You will need to jack your back end up pretty high in the rear but if you let the axle droop you can stuff them in and then slowly let her drop and adjust as necessary to get them in the right positon. I am trying to locate some 29" offroad tires and then I will have gained 4" of ground clearance. Suspension is much tighter but very comfortable especially for a little "light offroading"
Flex pic, currently sitting on 26" tires.
boise outlaw is offline   Reply With Quote
Old August 7th, 2015, 20:19   #2
SkyRyder55
Fuel Economy: 5 L/100kms
does it sit level? Rear looks way low but I know you are up on a berm.
PP764 nozzles, RC3+ tune, EGR delete with custom race pipe. MK4 Wolfsberg seats installed,
Bilstein HD, H&R Sport springs,16" Borbet rims,Rockford fosgate components front and rear, Alpine 12" Type R sub. Alpine 1000W Mono Amp, PPI 640 Watt 4 channel amp
SkyRyder55 is offline   Reply With Quote
Old August 8th, 2015, 04:31   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
That's as bad, if not worse, for the car as 'bottoming out".
On compression there are urethane bump stops to add spring rate and use up compression energy before reaching solid height on the shock absorber. There's no similar item on the extension stroke.
OK, I'll grant that the car body has more weight / momentum on the compression stroke than the wheel/tire/axle has on the extension stroke, but the 'slide hammer' effect as full extension is reached isn't beneficial.
If the quantity of carbonic acid increases in geometric progression,
the augmentation of the temperature will increase nearly in arithmetic progression.
Svante Arrhenius 1896
Cogito ergo soy (I think, therefore: Biodiesel)
Lug_Nut is offline   Reply With Quote
Old August 9th, 2015, 08:47   #4
boise outlaw
Talking
that is a "flexed" pic, front drivers is fully extended, rear drivers is fully compressed. Its more to show articulation, Extra clearance is necessary around here. I will take some more level pics of her when the build is done.
Static she barely sits at full extension, add a little weight to the rear and she rides great, usually have the top box and back end loaded up with camping gear. I believe that the guys using the lift spacers drill up near the top of the shock and add a 1" spacer so they can keep their shocks under full extension, but eventually i will just replace with longer ones . I still believe this is a superior option to the $300 spacer kit, and by playing around with how much you cut the jeep coil you could achieve the ideal lift for your vehicle.
Old July 29th, 2016, 14:36   #5
boise outlaw
update!
i've been running this for a year now and it is still working great! Had to replace the CV joints recently (i believe they were the original) and at 240k i think it was more due to wear then driveline angle. Will be upgrading the rear shocks to something a bit beefier and maybe with a little more travel but otherwise it is a solid design.
Old January 4th, 2019, 17:21   #6
peteguenther
TDI(s): 2003 Jetta
Fuel Economy: 40 in the hils 50 on the highway
Can you give a bit more info on what year xj coils you used and did you use fron coils in fron and rear in rear ( do those have rear coils? )
peteguenther is offline   Reply With Quote
Old January 6th, 2019, 06:11   #7
ZiggyoftheNorth
Also curious about an update. Did you find longer shocks and if so off of what?
ZiggyoftheNorth is offline   Reply With Quote
Old November 4th, 2019, 17:12   #8
WattIsGoingOnHere
Also would like to hear more about this setup and if you upgraded rear shocks
Sent from my SM-G950W using Tapatalk
WattIsGoingOnHere is offline   Reply With Quote
Old November 5th, 2019, 10:40   #9
Rob Mayercik
I haven't done this setup, but I do own an XJ and they're coils in front and leaves in back.
I'd guess the original poster used the front coils from a 4.0 (inline 6)-equipped model, which would mean anything from 1987-2001, but since it's been 4 years since the thread was started I have my doubts he'll be popping in to answer...
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is online now   Reply With Quote
Old November 6th, 2019, 15:42   #10
WattIsGoingOnHere
Yea I seen the date after I replied... rookie mistake lol
Old November 7th, 2019, 11:59   #11
Andyinchville1
Hi
Actually I read that cutting off from a coil spring makes it stiffer not softer. ... of course it also makes it shorter..
How much difference makes it I guess would be a percentage of the amount taken off... as far as business is concerned. .
Definitely going to look at this thread with interest because I wanted to make my car a little taller also but admittedly I did it with more conventional Jetta Springs
2003 Jetta tdi wagon , 5 sp, 316k miles, 11 mm pump, DLC 520, Malone stage 1, P205 70 R 15 Ecopias on Avus rims, hammer mod
Andyinchville1 is offline   Reply With Quote
spring ID... '03 jetta wagon ted andersen Upgrades (non TDI Engine related) 3 September 27th, 2010 18:02
WTB: Jetta Wagon rear towing springs, Koni Red wagon shocks, Metal Nerd 1" lift kit manics01 Private TDI Items for Sale/Wanted 0 May 10th, 2010 16:16
jaguar xj Jack_Berry Non VW Group Diesels 2 May 2nd, 2010 12:42
want a suspension lift in jetta wagon veggietdiwagon TDI Fuel Economy 8 November 30th, 2008 19:27
Need to lift 03 jetta wagon. odion VW MKIV-A4 TDIs (VE and PD) 5 August 1st, 2005 11:10
Page generated in 0.17318 seconds with 13 queries
[Output: 102.09 Kb. compressed to 86.75 Kb. by saving 15.35 Kb. (15.03%)]
