Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old October 24th, 2019, 08:12   #31
Lightflyer1
Lightflyer1's Avatar
That is the idea. Late injection events cause excess fuel to be burned in the dpf, turning the soot into ash at high temps. The water temp raises a few degrees IIRC but not any appreciable amount. I don't think my oil temp goes up any to be concerned over either.
Old October 24th, 2019, 09:31   #32
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
I know my car is in regen mode when the Exhaust temperatures shown on my ScanGauge are about 1,300 degF.
If its cool enough I'll idle until the temps are down to 300 deg.
If its hot outside I may drive around the block to let the temps go down before I shut the engine down.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old October 24th, 2019, 13:40   #33
Lightflyer1
But I think they were asking about engine temperatures (water/oil) not the already known exhaust temps. Those were already stated in their post.
Old November 2nd, 2019, 05:57   #34
vwexpress
Regen 101 for me please.
New to me 2015 golf Sportwagen, good shape, 25,000 miles. have only run 2 tanks of fuel, so I'm unsure if, or when it goes into regen. Still getting used to the regular driving motions and sounds of the car, but sometimes I notice something, is just a little different.
I drive a lot, like 600 miles or more a week, with a heavy load, like 600 lbs of tools. I'm assuming that it has plenty of time to do the regen when I'm on the hy-way, or either of the 55 mile one way trips....
vwexpress is offline   Reply With Quote
Old November 2nd, 2019, 17:23   #35
Lightflyer1
They will happen every 200 to 300 miles. Without gauges pretty much impossible to tell while driving highway. At idle it will idle slightly faster at about 1k rpms instead of around 800rpms. Fans will stay running on high when parked and shut off. With gauges from an OBDII dongle and an app you can see the exhaust temps and know when one is happening. VagDpf works for me and is designed just for this. I can see the soot level and know when one is about to trigger and when it is nearing completion, and then drive accordingly.
Old November 2nd, 2019, 17:30   #36
DivineChaos
i only notice the mpg go down and the egt go up to 1500f and the dpf rise to 1200f. yea it gets hot. i can feel the heat on my foot through the firewall. also the coolant temp rises.
DivineChaos is offline   Reply With Quote
Old November 2nd, 2019, 20:30   #37
vwexpress
Thanks for the info, I'm fairly certain that I'm just going to pound the miles on this thing, if it ain't broke, don't fix it.....
I also clicked in the how to upload pictures in you sig.... looks like I won't be posting pictures.
Old November 3rd, 2019, 07:49   #38
Lightflyer1
Why no pics? It isn't hard, you just have to host them somewhere, here or another site like Imgur.
Strange regen anomaly- Have you experienced a really long regen? DerekG VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 36 November 15th, 2019 09:03
Feeling the regen? Bob V VW MKVI-A6 Jetta Sedan (~ 2011+) 16 January 17th, 2015 11:42
loose feeling front end when driving??? mcarlito TDI 101 1 August 12th, 2014 10:02
Loose feeling front end when driving??? mcarlito VW MKIV-A4 TDIs (VE and PD) 2 August 10th, 2014 20:38
Driving style during regen? Henrick TDI 101 23 December 2nd, 2012 15:24
Page generated in 0.17046 seconds with 13 queries
[Output: 88.28 Kb. compressed to 76.08 Kb. by saving 12.20 Kb. (13.82%)]
