dingels75
I just completed my first timing belt change (the cars second). I purchased the TDIforum CD and followed it step by step with a laptop next to the car. All went well, I replaced all of the pulleys, tensioners, stretch bolts, water pump and seals and used blue Loctite on everything but haven't closed things up yet because there is one nagging question from the procedure bothering me. When I inserted the cam-lock pin into the injection pump, the procedure on the PDF of the CD states that it should be in approximately the 1 o'clock position. Mine was in approximately the 12 o'clock position. Does anyone have any experience with this detail? I'm looking for some reassurance before I button everything back up! Also, all four 6mm allen head bolts on the serpentine belt balancer stripped and I had to drill them out. Is this a common issue? I won't be replacing these with allen head bolts! Thanks!
