JaysinSpaceman
Yeah an update, it's about damn time.
So I have been busy with a bunch of work and other stuff and of course the personal stuff takes a back seat to the paying work. I have been doing work on this project but most of it really doesn't show. Like fixing a wee bit of rust in one front fender, removing a few broken off rusted stuck bolts, finishing some welding here and there, etc...
I do have a few pictures for you of somewhat interesting work. I welded up the turbo down pipe and found a waste gate to use for my DIY exhaust brake, bent up a pressure signal line to actuate the waste gate. This waste gate is set for 28 psi of back pressure which I am hoping will be enough braking force. If not I will have to add springs to it or figure out how to make it adjustable as it is not an adjustable waste gate.
Down pipe, waste gate, exhaust butterfly. As you can see the waste gate just dumps to the atmosphere, it really shouldn't be very loud as it will only be venting during deceleration. Worst I would think is it will make a hissing or fluttering noise.
Close up of the WG and the stainless pressure signal line.
As it is installed on the truck. It tucks nicely out of the way and clears everything well.
Remote oil filter mount. Cut out of 12g SS just because I had the SS laying around.
And the oil drain back for the turbo. Made from the original stock drain back hose ends (I couldn't seem to find a source for the solder/braze on banjo fittings which is why I decided to reuse them) and some 1/2" SS tubing for the hose barbs which I TIG brazed in place. I would have photographed this in place on the engine but you really wouldn't be able to see it in the picture. As installed it has a nice constant slope down from the turbo to the return on the block so it shouldn't ever have problems returning oil.
I also made up a new turbo oil feed line which needed a reused banjo fitting as well but I didn't bother to take a picture of it as it really isn't that exciting.
I also received my rebuilt injectors back with their new Bosio PowerPlus 764 nozzles, all cleaned and pop tested and calibrated. They should really wake this little motor up. The injector pump is also all buttoned up and I will be installing it when the motor comes back out for the clutch and engine compartment paint, etc...
I'll keep posting as I do work (which I hope to be able to do more regularly) and thanx for watching.
Jaysin
Jaysin
