Stix212
I have a 1982 vw rabbit that I dropped a 1.9td(i) year 1997.5 AAZ the mk1 rabbit was also a diesel. I have had the problem of when the power relay is plugged in there is constant power going to the glow plugs when I turn the key to the pre glow position and when I start the car it keeps going it does not stop so I have to pull the relay out once started. I feel there is a simple check maybe I hooked a wire to the wrong spot on the engine that tells it to turn off I'm not sure. I tried to hook all the wires back to the same areas of the engine so on. Any help will help an I am sure all you pro's know what I am doing wrong. Thank you all for any help.
