Dcc88
Hi guys, so I bought an old Mk5 Golf 2.0 TDI BKD engine. And a scan returned several faults - one of which was the camshaft sensor - so it took slightly longer to turn over. As this involved removing the timing belt I gave this job to it my local garage (who seem great). Now no fault and it starts bang on first crank. But it's so lumpy now! They advised me that my injectors needed servicing, and that's what's causing the lumpy idle. however the cost of servicing injectors are high, and since having the car for a month I needed to change the DMF/Clutch/Slave cylinder, then my injector/glow plug was playing up so changed the loom and glow plugs whilst there. Then the freewheeling clutch pulley was seizing - causing then you engine the rattle hard - drive belt tensioner was bouncing. So it's had a new alternator clutch pulley, tensioner and belt (why not for an extra 8 quid?!). So it's had lots of work done that I didn't initially expect. So that's the history. All labour at same garage. So I'm concerned with this timing, thinking that it's off. I've been researching loads and about torsion values and my baseline reading is way off! So far that I don't know what or how this has happened?! I'm hoping you guys or girls could advise me what to say to the garage? Also my idle fuel consumption is low either 0 or 0.2L! So surely something hasn't been timed correctly? Please help and see pictures of vag-com vcds screenshots. Oh and the car doesnt feel as nippy as it did! It's worth noting that when extra load is on the alternator (headlights and heater or AC) then the rough idling virtually disappears. I plan to upgrade the car - turbo and injectors - hence why I don't want to fork out for servicing these ones really!
Many thanks.
Dean
Many thanks.
Dean
