Old February 25th, 2017, 12:03   #1
Dalon
Fuel Economy: ~42
Default BRM Shaking/Vibration issues
So I have made threads on this but I'm not convinced yet that it is solely the camshaft causing my issues if it is. I had a timing belt service done on my car in August and ever since then my car has some shaking/vibration at low and high RPM. At high RPM, it gets worse as the RPMs increase. I am wondering if there is a problem with something related to the timing belt service? I read the tensioner can cause these symptoms and was wondering if anyone else here had an input on it? Thanks.
- I am going to have my camshaft inspected for wear at my next oil change. -
2006 Jetta TDI - 190k - EGR & Cooler Delete - ECS Dog Bone Insert - Frank06 Cam - Mufflerectomy - VAG-COM Mods: Disabled: Seatbelt chime, cold diagnostics, TPMS, and DRL - Tail lights set to 40% brightness, Recoded cluster to UK, Coming/leaving home, Remote windows, Unlock all doors
Dalon is offline   Reply With Quote
Old February 25th, 2017, 19:51   #2
Marinel
Marinel's Avatar
If the crank pulley was dropped during the timing belt change then that could cause vibration.
06 Jetta TDI 5 speed. Full straight pipe, Malone stage 2, EGR Delete.
85 MB 300d 235k miles and still going strong.
Marinel is offline   Reply With Quote
Old February 26th, 2017, 19:49   #3
paramedick
paramedick's Avatar
If it's a dsg, listen to the flywheel, too.
Old February 27th, 2017, 14:04   #4
Dalon
Fuel Economy: ~42
The dealer replaced my flywheel after this and it hasn't changed the noise
Old February 27th, 2017, 14:05   #5
Dalon
Fuel Economy: ~42
I had the dealer verify the work and they said it was done properly. I spoke with Frank06 and he recommends I check my torsion value so I am going to source a OBDII cable and do that and I'll update this thread!
2006 Jetta TDI has vibration/resonance at low & high RPMs Dalon TDI 101 7 April 28th, 2017 12:50
Another Timing Belt & Tensioner Issue vasillis75 VW MKIV-A4 TDIs (VE and PD) 2 September 14th, 2007 00:03
Timing Belt & Tensioner Failure KennyFlys VW MKIV-A4 TDIs (VE and PD) 3 August 26th, 2004 07:48
replacement timing belt & tensioner Veep VW MKIV-A4 TDIs (VE and PD) 4 January 9th, 2003 22:43
timing belt & tensioner jayhawk VW MKIV-A4 TDIs (VE and PD) 18 August 2nd, 2001 20:22
Page generated in 0.18594 seconds with 11 queries
[Output: 70.72 Kb. compressed to 62.39 Kb. by saving 8.33 Kb. (11.78%)]
