Tnairn
Thanks i sent Jeff a email, kermatdi also responded with a little interest
Problem with taking the DIY approach to tuning is that the software to needed to access the ECU to do it correctly is in the $5000-$10,000 range.You need a method of being able to read an eeprom on the board, change the appropriate bytes and write it back. Spend some time on ECU tuning forums, it's all there.
I never said anything about tuning, just removing the IMMO....Tuning is another whole can of worms.Problem with taking the DIY approach to tuning is that the software to needed to access the ECU to do it correctly is in the $5000-$10,000 range.
Correct - Torque, Dash Commander read OBDII data - BHW's Exhaust Temp sensor was not OBDII - only VCDS can read it.So, an app like Torque won't read it?
No, you will have to install another sensor. Any updates? Pictures?Is there a way to tie in the sensor so it cab be read through the same system or would i have to run justa external pyro like a autometer?
