I have some annoying alarms with my passat.
The engine light comes on at start up with the warnings emissions workshop. After a few miles a the traction control light comes on and I feel a bit of a shudder. The traction control light goes off when I turn the ignition on and off.
I have VCDS lite register version. I did a check and I get 1 worrying code about injector number 3.
1 Fault Found:
17675 - PD Unit Injector: Cylinder 3 (N242): Regulation Range Exceeded
P1267 - 35-10 - - - Intermittent
I also have an ABS ERROR code. Could the juddering be connected with that error or the injector problem.
I also have an intermittent fuel level problem where the fuel level indicator doesnt move.
any help or suggestions would be greatly received.
thanks
Paul
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine
1 Fault Found:
Readiness: N/A
Address 03: ABS Brakes
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 17: Instruments
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv.
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
27-00 - Implausible Signal
1 Fault Found:
thanks
Paul
Address 01: Engine
1 Fault Found:
Readiness: N/A
1 Fault Found:
1 Fault Found:
1 Fault Found:
