With a little help from Google I found out some things. It's VERY hard to get real numbers and prices about CNG home filling stations and I now know why.
The cheapest is called Phill, the numbers:
MSRP just under $4000, installation is extra.
Fill rate of .4 GGE/hour, that's around 50 cubic feet per hour. If you drive around 100 miles/day or more it will never fill the tank up completely over night.
Power usage is 1KWH continuous with limits on no more than 10 hours per day to let it cool off. So you're looking at least using 10KWHs per day.
6000 hours between rebuilds, $2000 to rebuild by a professional only.
As my daily commute is around 150 miles/day, the Phill home CNG station is not viable.
The good commercial filling stations that fill faster, run longer between rebuilds, and are cheaper to rebuild, are a lot more money, like starting around $9000 and go higher from there.
So unless one has a commercial CNG filling station in town, the home filling stations as they are now, are not practical. This is why you see a lot of fleet usage of CNG, the numbers work in that application.
