TBOxnitemare
I have so many things to do I thought I'd post up a build thread and see how others think or have input.
1996 Passat TDI - Purchased for $1,400
When I started
-97k on the cluster, however it has been changed as it reads unleaded fuel only so mileage is unknown and tachometer is off by quite a lot.
-Badly neglected maintenance except oil changes. Started in 0 degree weather after 20 seconds of cranking so I believe the glow plug circuit is having issues. Tests to come but putting that off since its above 60 now and starts up right away.
-Antifreeze is GREEN! You read that right, green.
-Soft brakes and completely useless. Grateful I had one e-brake left on the right side to get it home.
-Small rust spots, to be repaired later. A small mount of faded paint as well.
-Interior in great shape.
-CB radio in dash. Must come out.
-Upgraded stereo with 2 12" subs in the trunk.
-Unpredictable torque steer and pulls all over the place.
-Limp mode + no turbo.
-Brake fluid a decent color and clear.
-Idles at a good range and no misfire.
-Exhaust cut off 2 feet behind turbo. Probably wont change as I'm in an area without testing.
-Good tires just a tad dry rot.
-Not charging! 12V with a fresh battery but will not charge.
-Major oil leaks.
-No idea when last TB was changed.
-Saggy suspension.
-Engine vibration is terrible, even for a TDI.
-Bouncing tires over 40 MPH.
-No heat and a cable operates the blend door.
That's the bad but I promise it gets better!
Done list will be posted next.
When I started
-Major oil leaks.
-Saggy suspension.
