JFettig
You are correct Ryan! had some miscommunication with him, its all straightened out.
Finally, a good use for an 01MI think that's quite possibly one of the coolest pics I've seen in a while haha! Never thought of that option, should work perfectly!
I'm sure I have a used 02m slave or two laying around. What measurements do you need or do you want the whole thing?
perfect reply.Finally, a good use for an 01M
That's exactly what I was thinking!Finally, a good use for an 01M
I've got a 02M bell housing case with a busted piece where the mount goes.I am tempted to but it doesn't deserve to be chopped up.
When I started, I figured the 02J setup would be a lot easiest, then I ran into the 01M case and got the idea to use the 02M throwout bearing. I'm not sure I want to scrap out my 012 just yet. I'll explore this one a little further to see if it will be worth using, otherwise I can still use it or find another one.
TurboJohann sent me some pics of his, it is what he used and doesn't look as difficult as I thought it would be to make it work. The slave cylinder is kind of weird how it mounts but probably wouldn't be a problem. Originally I thought about bolting or welding a plate on the back of it, but it would end up right in the center of the diff housing. After seeing how Johan did his, it shouldn't be too difficult.
I also recently discovered how easy it is to move the motor forward in the engine bay by just lengthening the shaft coupler that connects the shaft to the transmission input shaft. I'm moving it forward about 2", possibly more.
magnesium? so would be much harder to weld then?....that's good info...I'll steer clear of busted 02M's thenmmm tempting. 02M is a magnesium alloy, not sure how to relocate the starter.
240mm flywheel would be nice!
I'll send you a pm!
If you get any flack, just tell them Ferdinand Porsche founded both the VW and the Porsche companies... You're just going back to the roots and combining both!I still think I'm gonna get LOTS of flack from the Porsche guys for doing this
Jon
Nahh the 944/924 is half VW..I still think I'm gonna get LOTS of flack from the Porsche guys for doing this
Might want to consider an 01E bellhousing, I have plenty of those I can donate. Starter goes in on engine side and you get a 240mm clutch.I still might use the 012 5spd trans I have for the bell housing. Its a shame to dice up a perfectly good trans.
That was kind of the thought, at least originally. Some of the things I need to do to get it running at all require extensive modification, to the point where it makes sense to just do certain parts of it from the beginning and not do it again.Wouldn't it have made more sense to have it running and reliable before spending your money on engine upgrades? Neat project, but most of us driving completed conversions know how much work it is just to get it running and reliable. Just a thought.
