Hi All,
I have a 1997 Tdi which suffered a lot of electrical damage when the main electrical harness made contact with the fan. I have put the car together as best as I can, although the VSS does not work (I use a GPS speedo) and the coolant temp sensor does not work (i installed an aftermarket coolant temp gauge).
I do not believe the glow plugs are cycling at all. The glow plugs are all new Bosch and the car has trouble cold starting at around 40 deg F, although it would usually start. On a few nights, it froze and I started around 32-35 deg F in the morning and it took several tries. The engine otherwise runs like a champ. The IP timing is good and verified by VAGCOM.
My plan is to eventually swap the engine into a Samurai, but I need to get a bunch of pieces together first.
I am looking to put together a push-button to manually energize the glow plug relay. I have seen a thread where this was done (http://forums.tdiclub.com/showthread.php?t=264313), but I'm not seeing enough detail to give me the confidence to start cutting into the wires.
Has anyone done this? It would be good to start with other documented projects if there are any.
Just to be clear: my OEM setup is completely FUBAR. I have already spent *a lot* of time and money and talked to a bunch of experts to fix the OEM setup. When the car starts, it runs just fine. I have already driven it cross country and put on a lot of miles like this.
Thanks,
h.ubk
Thanks,
h.ubk
