Richardsoc
Hi
I have a seat Leon 2001 1.9 tdi asv engine and have recently had a new n75 solenoid fitted. But this morning I broke down,
if reved high it either cuts out and wont start for some time, and then sounds like theres no compression. or, also after the wont start problem, itll just run on a few cylinders and beltch smoke until, after some gentle reving, it seems to un stick something which then alows the engine to rev, and the smoke clears.
When I disconnect the air mass it sounds and revs fine and when I drive it , it doesn't cut out there's just not as much power there was befor.
There are no fault codes
Any one help...
Thanks rich
Any one help...
Thanks rich
