angrywasp
Just got my first TDI but I grew up with NA VW diesels and have had diesel trucks. Car has 298K on it and I have no idea of maintenance history but it fires right up. Issues with the TDI are a complete lack of boost (top speed of 67 mph), grind/crunch when shifting into 1st at a stop (no noise when moving), and some alternative electrical engineering from the power block to the injection pump (I think). I've pulled the intake hose off the turbo and turned it by hand. It's smooth and easy to turn. I also tried moving the vane rod and it developed resistance after about a 1/2" of movement which is correct I think. I was going to try running the car without the turbo vac line hooked up and use my mighty vac on it to adjust the vanes but the car was completely dead. Pretty sure it's due to the electrical engineering. It's a switch that keeps the car from starting somehow. I'm planning to pull it out if I can but I don't know the wiring of the car. Not sure if the crunch is clutch, slave, fork, or what. I'm open to any and all ideas.
