Door not opening
Penaran561
Rochelle, IL
2013 Passat TDI SEL
My driver's door is not opening when I unlock. All other doors unlock. Only time it opens is after I start the car. Sometimes the door doesn't open from the inside even if the car is running. What could be the problem?
Nebelwerfer
Canuckistan
2012 Passat TDI
Too much moisture in the door mechanism and the colder temperatures outside freeze it up.
That'd be my guess. I've had a similar issue in the past.
A hairdryer sorted it out.
Regards
Jimbo70
New Milford, CT
None currently
This is a known problem with Passats of this vintage, or at least it was when it happened to mine. IIRC, there is/was a recall on this issue, or at least at TSB. I cannot recall whether it was repaired under the car's warranty or under the recall.
Mark_J
Deer Park, Washington
2015 TDI Passat SEL Premium, 2017 Fiat Spider, 2017 Ford F350 6.7 Diesel crew cab PU, 2016 Harley Trike, 2016 Tesla Model X P90D (I know went to the dark side)
Fournd the technical bulletin & Tech Tips from VW
Here are the technical bulletin & Tech Tips from VW
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM506325/SB-10055398-2897.pdf[/IMG]
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM506326/SB-10055398-5668.pdf[/IMG]
Mark_J
Just tested the links and they do not work. I have the 2 docs saved as PDF but don't know how to attach them. Can someone point me in the right direction. Thanks
VernK
Kelowna
2012 Passat 2.5L Gas
Sadly, no way to attach files directly in this forum software.
If you email them to vernvan@gmail.com, I'll throw them on a webpage and put up a link here.
Yours
Vern
Mark_J
Thanks Jimbo70
