Old November 8th, 2019, 16:45   #16
WildChild80
WildChild80's Avatar
Originally Posted by absalom View Post
If I were to do aftermarket deck, what's the exact part number for the proper Metra adapter(s)?
Amazon
WildChild80 is offline   Reply With Quote
Old November 8th, 2019, 21:12   #17
wonneber
Originally Posted by KrashDH View Post
I wired a keyed relay to take care of the amp issue. Didn't want any parasitic drains which it was known to do.
I must be a lucky one but my OEM Monsoon system is awesome. Speakers are still good and I think it's actually a great sounding system. Aftermarket Kenwood deck though as the OEM deck bricked itself (literally just froze one day)
I thought the Monsoon sound quality was OK. Nothing to get excited about.
The Kenwood DNX571HD I got is way better.
I pulled it out of my 03 Jetta and will be installing it into my 14 Jetta in the near future.
Just my 2 cents.
wonneber is offline   Reply With Quote
Old November 9th, 2019, 11:27   #18
caligta
If you are switching to a single din I would opt for a used OEM pocket (1J0 857 058 B) as the Metra one doesn't look that good IMO.
When I did my 2003 Jetta I ran a power wire over from the ignition, but for my 2003 Golf I used an Axxess XSVI-9003-NAV Interface Harness and I think it was worth the money.
You also need an antenna adapter.
caligta is offline   Reply With Quote
Old November 9th, 2019, 12:08   #19
eddieleephd
Fuel Economy: 38mix / 47@70-75
This one had good info
https://forums.vwvortex.com/showthre...topics/2465170
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 12th, 2019, 08:09   #20
timestar
How do you turn off amp/crossover in trunk other than cutting the wires - 2002 Jetta TDI?
timestar is offline   Reply With Quote
Old November 12th, 2019, 08:24   #21
eddieleephd
Probably the fuse up front...
Old November 12th, 2019, 20:12   #22
wonneber
Unplug it?
Old November 12th, 2019, 20:19   #23
wonneber
Fuse 42 powers the amp and the radio.
If you get an adapter cable the radio won't have power.
Power to the amp was the biggest reason I removed it.
I also ran all new wires so I did not have the VW tiny wires.
Old November 13th, 2019, 08:00   #24
hskrdu
absalom, this thread has some more p/n's for OE VW 1DIN radios:
http://forums.tdiclub.com/showthread.php?p=5550655
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD & 2015 GSW TDI 6M
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old November 13th, 2019, 08:29   #25
KrashDH
TDI(s): 2002 Golf
I mentioned this earlier in the thread, I'm not sure why so many remove the amp out of the system. Hook up a relay to switched power to definitively turn the amp on and off and then there's no issue with any parasitic drain
KrashDH is offline   Reply With Quote
Old November 13th, 2019, 12:28   #26
wonneber
Two reasons I removed it.
The replacement already had more power then I need.
I ran all new heavier speaker wires to each speaker and didn't want the power feeding backwards into the amp output.
I did have to replace the rear speakers at some point.
Old November 13th, 2019, 14:20   #27
KrashDH
TDI(s): 2002 Golf
Gotcha.
Yeah if I was re-doing the system completely that amp would be out and I'd buy aftermarket amp/speakers/wiring.
Did that for my truck (pretty standard amp/sub/speaker setup) and boat (had 3 zones of speakers and subs that were being powered by 2 amps)
Old November 14th, 2019, 17:32   #28
GEFP
subscribed
GEFP is online now   Reply With Quote
Old November 15th, 2019, 05:14   #29
timestar
Default Turn Off Amp/Crossover
Hello,
Have 2002 Jetta TDI. Recently installed FH-S701BS Pioneer double din radio. Crutchfield recommends Fosgate speakers with tweeters. They have inline crossover. How do I turn off crossover in trunk other than cutting the wires?
Thanks,
Robert
Old November 15th, 2019, 11:53   #30
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Discussed in more detail earlier in thread. If you're not using it, unplug or remove conductors, nearest the head unit would be best. Cut the wires is a summary type answer, you never want to leave open conductors.
Help me please! Stereo upgrade StylinBill Upgrades (non TDI Engine related) 14 March 9th, 2014 18:44
Time to upgrade the stereo (not too much though) TopherDI VW MKIV-A4 TDIs (VE and PD) 31 March 10th, 2011 16:45
Stereo upgrade dilema... euromade Upgrades (non TDI Engine related) 34 November 13th, 2007 04:28
Stereo Upgrade KorMelisTDIJetta Upgrades (non TDI Engine related) 7 June 7th, 2004 22:16
Stereo Upgrade Quench Upgrades (non TDI Engine related) 4 August 25th, 2002 22:22
Page generated in 0.16339 seconds with 13 queries
[Output: 125.81 Kb. compressed to 105.33 Kb. by saving 20.48 Kb. (16.28%)]
