Elou795
Hello, I'm having a problem with my high beams, when I push the lever forward the high beams don't work, but when I pull the lever towards me in flash mode the high beams work fine.
Now my question is could I have a bad high beam switch on my turn signal lever, is this something I could test with VCDS, has anybody ever seen the high beam switch go bad?
