We have 2001 Jetta with approximately 180,000 miles on a replacement used engine, (the original engine had a rod snap), 340,000 miles on the car total, and we have been experiencing a low power problem for quite some time now. The engine starts, runs just fine with normal cruising around town there are no noticeable problems. But, when pushed, it seems to accelerate well until around 2000 RPM where it starts to bog down and the power flattens out. At highway speeds, when climbing hills, the turbo will sometimes kick out, necessitating shutting the engine off and restarting. I have beat on the catalytic converter and there are no rattles. The car has been into the local VW shop several times where the MAF, fuel filter and all the vacuum lines have been replaced, the intake manifold cleaned, the fuel pump timed, all with no success. The shop says that the turbo itself is operating normally where they are stumped also by this problem, suggesting that I just drop the car off so they can experiment as time permits, but before I do that I would appreciate any further thoughts and ideas?
Thanks,
Bill
Thanks,
Bill
